...68, did you solve problem ?
i have 9.0.48 from 2006/09/12, with such design like on that picture with 4 players... it is for 2091 (if you saw that inside player)... ¤ |
...68 - here is file - try it.. i must go home now..
http://rapidshare.com/files/45178661...01_1G_2091.rar pls post me on PM ! if you take file so i can delete it from net.. tnx.. |
Re: Dead player, looking for firmware ACT2097_S75 ver 9.0.48
ill download the firmware but i will just post my result because im having trouble with the player PCB now ill try to fix this first then ill try the firmware...ohhh... i almost fogot the chip is ATJ2091H and the memory chip is made from korea..thanks to you all for helping... i will just fix the PCB first...hehehe...got messsed up in desoldering the lead in the chip...my fault..:(
by the way do you have any schematic diagram of this player
http://www.isikcomputer.com/urun_picture/3882529_0.jpg |
Unfortunately i wasn't able to find a schematic for your player. What is wrong with the PCB ? Did you try to desolder the main chip?
| All times are GMT -7. The time now is 10:57 pm. |
