HELP! ~ Dead 2GB Rockchip 2.0" Screen
Old 28th Jul 2007, 8:35 pm
Default HELP! ~ Dead 2GB Rockchip 2.0" Screen
Hey, I have a Rockchip player exactly like this one:
It randomly showed up a white screen after leaving it on the USB charger for too long. I read a lot on the forums and found out about jumping the chip to go into recovery mode to update the firmware with Consumer Tools. Well, after trying dozens of .rfw files some work, but not correctly. The closest firmware I found was Ver0.0.6.rfw which was uploaded in this forum. It works perfectly except the button layout is messed up, i.e. when i press the volume button it goes down and the down button goes up. The volume up button makes the volume go down when playing music and NO buttons make the volume go up. Is there any way I can get a clean version of this firmware like it was before? I've literally tried ALL the .rfw files found on this site.
Old 29th Jul 2007, 12:24 am
Default Re: HELP! ~ Dead 2GB Rockchip 2.0" Screen
I have the exact same player as this. I lost the screen on my player too.
The firmware I used to get I back has been post on this site already here:-
All Rockchip Firmware
It is rockchip 00.00.0001 ver by 17.01.2007 and is posted by "puwkin"
I bet you haven't tried this one.
Try to load this into your own version of ConsumerUpdate that came on the Cd with your player, If comsumerUpdate accepts it, then try upload it to your player.
I assume that you are able to get into update mode with your player. Don't short out any pins on the chip if your player still plays music, you can still navigate the menu.
This firmware defaults to Hebrew Language, but there are European languages on it too, you just have to navigate the hebrew menu to select them, English is 3rd from the very top of the list. To select a Language I had to press the play button for some reason. Hope this works for you..
Old 29th Jul 2007, 1:51 pm
That one gives me a white screen also. My CD came with no consumer update but did come with MP3 player utilities but that does not restore firmware for rockchip flash.
Could I be using the wrong version?
Old 29th Jul 2007, 2:31 pm
The version of Consumerupdate I used was 2.7.6.
Another firmware which worked for me was the walker.rfw, but it made the screen too bright on my player but at least you could see the menu, you might want to try that.
Old 29th Jul 2007, 7:43 pm
I can only find 2.61.2, which may be why its not working.
Is 2.7.6 uploaded here?
Old 29th Jul 2007, 11:44 pm
O.k, I've uploaded the ConsumerUpdate version 2.7.6, that came on the Cd with my player
together with the firmware (2" screen) that I used to recover my player.
It worked for me and my player looks exact like the player in the pic above.
Old 29th Jul 2007, 11:47 pm
Will it take time to get into the download section? If this works you're definitely getting posted on the most helpful user announcement. :]
Old 30th Jul 2007, 12:40 pm
Nope, still a white screen. I guess I'll just keep trying different firmwares with this new program and if nothing works it will sit in the bottom of a drawer.
Old 31st Jul 2007, 12:52 am
Have you tried the DEC 690 firmware?
I didn't work on my player but your player is different of course so it may be worth a try, on the outside they look the same.
It think it uses ConsumerUpdate v2.61.2.
links here:-
DEC 690
DEC Firmware
Old 1st Aug 2007, 4:53 pm
No good, but thanks anyway. I guess I'm just SOL :roll:
Rockchip 2706 dead, > Red screen robin1337 Dead Players 3 12th Jul 2010 4:17 pm
Can't "unlock" 16GB 2.8" Touch Screen MP4 player javitony Dead Players 5 16th Dec 2009 8:15 pm
[solved] Rockchip mp4 - "file format error" on AVI video files haruya Video related 6 5th Dec 2009 6:51 am
AVI File problems on a Rockchip 2.8" Touch Screen Playe mbd_darkstar Video related 2 24th May 2008 6:42 am
rockchip player 2,2" 320X240 screen file format error electrodj Video related 7 26th Mar 2008 6:47 am
