Who has 2" 2GB or 1GB!! MP4 from eBay power_player88
Old 2nd Aug 2007, 1:42 am
Default Who has 2" 2GB or 1GB!! MP4 from eBay power_player88
If anyone has a 2" 2GB or 1GB!! (mine was sold as 2GB & initially appeared to be but turned out to be 1GB after checking) MP4 player from eBay power_player88.
Player here: 2"Screen 2GB MP3 MP4 FM Player with case wht 0.99.
It is still working, please can you take a raw copy of the flash using s1clone tool from www.s1mp3.de. Do this with the player's disk empty of files as the image will be enormous if it's not.
It is impossible as far as I know to find firmware for this - I think its 9.1.51 but again, it would be good if you checked on your player settings. Although there is mention of a website for firmware in the listing, it does not appear to exist. If you're able to run this tool & produce this file please upload it to the site - I think you'll be v popular, not just with me but with many others.
Thanks in advance
eBay seller "supergift468" sells hacked 8GB player dittoLIVE Bad sellers/Blacklist 0 10th Mar 2009 9:54 pm
eBay seller "tronicguard" sells hacked 8GB players dittoLIVE Bad sellers/Blacklist 0 10th Mar 2009 9:48 pm
eBay seller "rencai-y" sells hacked 8GB players dittoLIVE Bad sellers/Blacklist 0 10th Mar 2009 9:11 pm
luckytolife merci_online power_player88 your.discount.shop knebus Bad sellers/Blacklist 1 16th Dec 2007 12:49 pm
