  #81 (permalink)
Old 13th Oct 2008, 10:07 am
hi tuso
I don't think you have damaged the memory.
I have had the black screen problem many times before too, but I used the hardware recovery to get it back, you just need to try a bit longer to get it back, but only the hard recovery will get you out of a black screen if you keep trying.
  #82 (permalink)
Old 13th Oct 2008, 10:44 am
Originally Posted by knob";p=&quot View Post
...you just need to try a bit longer to get it back, but only the hard recovery will get you out of a black screen if you keep trying...
Thx Knob. But I can recover my MP4, even if my PC dont recognize them???
I ask this because, as i said before, my PC dont recognize my player as a USB storage device, or as a Rockchip USB device.
Anyway, I keep trying, thanks for your help and for this fantastic guide.
  #83 (permalink)
Old 13th Oct 2008, 8:27 pm
Default Re: Rockchip DEAD Player Recovery Guide
Hey.
Now my PC recognize my MP4 as a rockusb device, but now always when i conect it, my PC assumes that is a rockusb device and dont recognize as a usb storage device!
And I apply my factory firmware but anything happens. It still have the black screen and anything is turn on.
Thats normal? What can I do? Anyone can send to me a firmware?
Here I post some information, taken with ChipGenius:
Device Name: +rockusb Device
PnP Device ID: VID = 071B PID = 3202
Serial Number: 5&&2D5E1365&&0&&1
Revision: (Information not returned)
Device Type: Standard USB device - USB2.0 Full-Speed (USB1.1)
Chip Vendor: RockChips
Chip Part-Number: RK2606
Product Vendor: (N/A)
Product Model: Recovery
Tools on Web: (N/A)
My MP4 is the same as this. Its a 2.8'' touch screen player, 4GB with option to expand up to 8GB via miniSD card.
Thanks in advance.
  #84 (permalink)
Old 29th Dec 2008, 3:18 pm
um i was wondering i have a rockchip mp4 chipset 2606 2.4" screen with fm and micro sd kinda like a meizu looking mp4 anyways... did the recovery and it gives me white screen , pc sees it as mass storage device, do i have the wrong firmware? and if so can someone help me get the right one the original ver. that was on it was 00.000.001 also the on/off button is locked and i dont know how to unlock it any thoughts?? plz help many thanks DP..
  #85 (permalink)
Old 30th Dec 2008, 1:11 am
Can you post your player details in the form:-
Control: example - RK2606
Plate No.: example- ZX-6160L
Screen No.: example - LKD-1697U-U2
http://www.mympxplayer.org/s1-mp3-pl...om-vt8930.html
  #86 (permalink)
Old 1st Jan 2009, 4:47 pm
this is the text on the board/ HY205(203B,211)-MB-AV4.0(FM)
2006-1-20
Ropckchip 2608a
Ram/ HYNIX KOR
HY27UU088G5M
TPCB 71QA
and thats all there is thanks for your kind help dp
  #87 (permalink)
Old 2nd Jan 2009, 4:30 am
hi demonspride
Give this firmware a try:-
http://www.s1fw.com/plus/download.ph...id=37287&cid=3
  #88 (permalink)
Old 2nd Jan 2009, 8:55 am
the upsate for rockchip says there is an error in rfw file
Any ideas?
  #89 (permalink)
Old 2nd Jan 2009, 11:49 am
There are chinese characters in the filename, you need to delete then and try again.
  #90 (permalink)
Old 4th Jan 2009, 12:28 pm
tried it gives me white screen anything that can save it?
please DP
