pleas help me with my dead players
Old 5th Aug 2007, 5:09 am
Default pleas help me with my dead players
i need search firmware for this mp4 player
merory : hynix hy 27uu088g5m 8Gb
chip:ATJ2091n
bord:SRX-C3-91 vesion 0.2 2006-10-21
1.5lcd display ,radio fm and 3.5v batery :cry: :cry: :cry: pls help me
look at this picture:http://en.wikipedia.org/wiki/Image:C...mp4_player.jpg
Old 5th Aug 2007, 7:23 pm
Fllex , the Hynix 27uu088g5m is a 8Gigabit (1GigaByte) memory chip. So if the seller sold it to you as 8GB, then it has been hacked.
Your player would be using the v9.0.xx series firmwares here http://www.mympxplayer.org/actions-9...mare-dc37.html
You'll need to try every single one for 1.5" screen until you get it working again.
If it does not, then there is nothing much you can do as the firmware extraction tool S1fwx currently only supports upto v9.0.43, so others with a working player are unable to dump their firmware for you to try.
Old 8th Aug 2007, 12:25 am
hi i need firmware for my fake ipod nano too,
the specs are
ATJ2085W
Hynix KOR HY27UG084G2M
MP-693C-sl
v1.3 2005-12.14
Old 8th Aug 2007, 2:10 am
hsals666 , your player would be using the v3.5.xx series firmwares.
v3.5.35 here http://www.mympxplayer.org/actions-3535-dc15.html
v3.5.37 here http://www.mympxplayer.org/actions-3537-dc16.html
As there is no way of telling which firmware would work properly for your player, you'll need to try all the firmwares for your screen size.
Good luck.
Old 8th Aug 2007, 3:13 am
i need to try all the firmwares in the link that you've given me?
Old 9th Aug 2007, 10:11 am
lattesurf!!
i tried all the firmwares in the link you've given me,,when i use version 3.2.XX the program says Update is success the program will exit but the driver is still dead and it becomes unrecognized,,the icon of removable drive will disappear,,and when i use 3.5.35 and 3.5.37 the program says Read or write device information failed! Please exit the program and check if device is connecting! sometimes Flash is no responding or Unknown Flash type ,,unknown Flash error also...
Dead Players Alex07 Dead Players 1 20th Apr 2008 10:12 pm
dead players radhika Dead Players 1 21st Aug 2007 8:49 am
Pleas help... bigspeen Support and How To 0 10th Apr 2007 9:56 am
8 gig nano look a like not playing any amv files. help pleas hellbound Support and How To 9 9th Jan 2007 2:12 pm
dead players skater88471 Dead Players 1 29th Sep 2006 7:57 am
