firmware need helpme
Old 7th Aug 2007, 11:42 am
Default firmware need helpme
help me !!!!!!!!!!!
Player only shows a white screen !!!!
I can`t find the firmware for this !!!!!!!!!!!!!!!???
2606a
Thanks.
Old 7th Aug 2007, 12:40 pm
What screen size is your player, 320x240 or 220x176?
You need to get your player into update mode and use ConsumerUpdate to flash the correct firmware for your screen size.
What you need to do is this,
1) Switch the player OFF using the main on/off switch.
2) Hold down the menu key and keep it held down.(may be a different key for you, can be Play key or Volume key, but there are only 5 to try anyway)
3) Connect the usb to the player.
4) Wait for about 10 seconds before releasing the menu key.
5) You are now in upgrade mode
6) Then just connect ConsumerUpdate and upload a working firmware.
ConsumerUpdate should also REBOOT the player before starting the upgrade.
There are some Rockchip Firmwares to try in the downloads on this site,
Looks like a DEC A780
DECA780
DEC Downloads
Old 8th Aug 2007, 12:35 am
220*176
its not work on 2.7.6 tool
Fw is not match this tool
how ? !! thanks
Old 8th Aug 2007, 9:37 am
Try this firmware:-
http://www.mympxplayer.org/rockchip-...276-df612.html
ver 2.7.6 will accept this, I used it to recover my player.
Old 9th Aug 2007, 3:43 am
i try but but not working !!
windows detected rockchip but when i press updates button :
manufacturer or NAND flash no be supported
i think it need some *.rfw older ! because i buy this player 1,5 year ago !! i lost all manual and cd-rom. please help me again. thanks so much
Old 9th Aug 2007, 3:45 am
this file what for " RockchipFull220x176.Lst "
I have MP4 player dead helpme please darkpower15 Dead Players 3 11th Nov 2007 5:27 pm
The admin, can you helpme??? Stranyer Support and How To 0 20th Dec 2006 7:49 pm
HELP ME! HELPME! PLEASE for mp4 mp680-cl-v11 serrefloralia Dead Players 0 10th Nov 2006 3:28 am
