Need Firmware for this!Please need help!
Old 8th Aug 2007, 11:12 pm
Default Need Firmware for this!Please need help!
Board:MP-693C-SL v1.3 2005-12.14
Processor:ATJ2085W
Memory:Hynix KOR HY27U084G2M
ACTS16D_13
2005/06/01
WS-3.2.16
2005/09/08
please help find the right firmware for this.
my mp4 player looks like this,and the menu are the same.
i dont know if the features are the same,but the outer look is the same so as the menu..
http://www.mympxplayer.org/image-full-asp364.html
Old 9th Aug 2007, 1:29 am
hsals666 , it is not possible to tell which firmware would work properly with your player. The only way would be try all the v3.2.xx and v3.5.xx firmwares.
v3.2.xx here http://www.mympxplayer.org/actions-32xx-dc14.html
v3.5.35 here http://www.mympxplayer.org/actions-3535-dc15.html
v3.5.37 here http://www.mympxplayer.org/actions-3537-dc16.html
Good luck.
Old 9th Aug 2007, 2:23 am
okay ill try and ill let you know what happens,,
wait,,what does Read or write device information failed! Please exit the program and check if device is connecting!,,,Unknown Flash Type,,Invalid Upgrade Firmware File,,Flash is no responding,,,unknown flash error means....coz i keep on getting those messages when i try to recover my player..
Old 9th Aug 2007, 10:37 am
lattesurf,i've tried all the firmwares in the link you gave me,but still it gives me the errors,Read or write device information failed! Please exit the program and check if device is connecting!,Flash is no responding,,unknown flash type,,unknown flash error,,invalid upgrade firmware file,,what should i do?
