DEAD MP4 PLAYER PLS HELP
Old 15th Aug 2007, 7:56 am
Default DEAD MP4 PLAYER PLS HELP
Hello EVERYONE...
I want to ask you a question about the mp4 player that i bought 10 days before.
I was very happy to have a mp4 player like it, because it was the thing i want.
I uploaded many mp3 and mp4 and amv and wav files into it.After i saw the mp4 player doesn't see the whole files and doesn't play the amv and mp4 files, I formatted the player with the tool you send me in the driver cd.And i saw that the disk capacity get to 956 mb from 2 gb.After all i wanted to upgrade the firmwire.I did it and now my player doen't open and work.There is nothing on the screen.But it is seen as a usb flash disk with 956 mb capacity.Before this it was a adfu? usb thing.But now i am loading new and varius firmware to it but there is nothing on the screen.With some firmwire files the screen gets blue or white only ...Before upgrading firmwire i have got the clone image of the player with s1clone software.But i can't upload this img file.
The 1st fw was
9.0.50
atc209x_s75
.Please HELP ME !!!
Old 15th Aug 2007, 5:24 pm
drhlkaplan , very likely your player had a hacked 1GB memory chip. The formatting removed the memory hack.
Have a look in the CD that came with the player for any firmware files (usually in .fw or .bin format). If not, try contacting your seller and see if they have the firmware file to send to you.
If all these do not work out, then you'll need to try all the v9.0.xx series firmwares here http://www.mympxplayer.org/actions-9...mare-dc37.html
As the extraction tool currently only supports v9.0.43 and below, you might have a problem of locating a suitable firmware for your player.
Old 16th Aug 2007, 7:45 am
Thanks lattesurf, i will try all 9.x.x fw .I have contact to the seller.He wants to change it or refund but i want to use that player.The shipping takes about a month if i send it to the seller.There was nothing in the driver cd.
Old 16th Aug 2007, 11:17 pm
drhlkaplan , the easiest solution would be to get an exchange or refund. As the firmware extraction tool currently only supports upto v9.0.43, you might likely face a problem of locating a compatible firmware for your player.
MP4 DEAD THIS IS THE CPU AND BOARD POST, DEAD PLAYER manikakoto Dead Players 0 9th Feb 2009 3:08 pm
Dead Player i think very dead... DzoniHSV Dead Players 13 10th Aug 2007 12:13 am
dead player, so very very dead Kosh Dead Players 4 1st May 2007 6:48 am
Dead well almost dead MP4 Digital Player Zest Dead Players 6 28th Jul 2006 9:59 pm
