help my player wont open anymore =(
Old 18th Aug 2007, 6:56 am
Default help my player wont open anymore =(
guys i need your help. i crashed my sony mp3 player. where can i get its firmware? version 9.0.50
or how can i make it work again?
i tried putting a new version but mp3 player firmware upgrade tool stops when upgrading on the part that says "displaying the communication picture"
Old 18th Aug 2007, 7:40 pm
jigoku , try all the v9.0.xx series firmwares here http://www.mympxplayer.org/actions-9...mare-dc37.html
As there is no way of telling which firmware would work properly with your player, you'll need to try all of them until you get your player working again.
If the upgrade tool always hang while flashing the firmware, try uninstall and re-install another version of MP3 Utilities. There are many versions available in the downloads section.
Help: my computer is not recognizing my mp4 player anymore kalaslsl Support and How To 4 25th Apr 2009 7:02 pm
PC will not recognise my player anymore mashimo Dead Players 14 28th Apr 2007 7:44 pm
'ILLEGAL HDD' on the screen and wont open any files stonecoldsteveaustin Support and How To 5 18th Apr 2007 12:54 am
Player Cant Open Files anymore macko187 Support and How To 1 31st Mar 2007 6:42 pm
[solved] after about 100 tracks, wont take anymore bravehearted Support and How To 3 15th Jan 2007 7:40 pm
