-   -   need firmware for SUNPLUS SPCA536A-PB111 (http://mympx.org/forum/dead-players/38708-need-firmware-sunplus-spca536a-pb111.html)
lolipop 18th Aug 2007 7:10 am
hello every body i need firmware for SUNPLUS SPCA536A-PB111 (256 mp)
thank you
lattesurf 18th Aug 2007 7:39 pm
lolipop , unfortunately there are no tool available that i know of that could extract Sunplus firmwares. So you'll have a problem locating a firmware for it.
Most cases, Sunplus players once dead, needs to be sent back to the factory to be factory-resetted. i would suggest that you contact your seller for an exchange if it is still under warranty.
lolipop 18th Aug 2007 8:02 pm
Re: need firmware for SUNPLUS SPCA536A-PB111
thank you lattesurf, for your reply
my mp4 sunplus finsh warranty now
i try to remove flash ic chip and i will update the firmware
