firmware for atj2091n samsung 710
Old 18th Aug 2007, 2:38 pm
Default firmware for atj2091n samsung 710
hi all me again i have managed to kill my other mp4 player nano look a like it first started with the hour glass on the screen then i tryed to format it but no luck as it wasnt being reconised on my pc so i followed the dead recovery guide but now all i get is a white screen can any one tell me where to get the correct firmware for this player
1.5 inch screen
was 8 gig now 2 gig after removing the hack
samsung 710
k9lag08u0m
atj2091n i think this is the processor
g208fb 52r
many thanks
jason
Old 18th Aug 2007, 7:36 pm
jason , your player would be using the v9.0.xx series firmwares here http://www.mympxplayer.org/actions-9...mare-dc37.html
As there is no way of identifying which firmware would work properly with your player, your only option is to try all of them.
Old 21st Aug 2007, 2:55 pm
Default Re: firmware for atj2091n samsung 710
hi lattesurf thanks for the reply i have been trying the firware v9.x.xx since you have replyed and still the player is dead i am getting an error message from mp3 upgrade tool program saying invalid firware upgrade file, i have tryed others of the 3.x.xx and still the same errors are comeing up.
this is the same player in side if that helps http://www.mympxplayer.org/image-asp392.html except the Processor chip is a differnt number to mine.
im not sure what to try next if you could advise me on what i need i would be realy greatfull.
Old 21st Aug 2007, 3:24 pm
jason , have you unpacked the firmware files? The files downloaded from this forum are usually compressed .7z, .rar, or .zip files. You might need add the extensions and unpack them before you can use them on MP3 Utilities.
Old 22nd Aug 2007, 11:57 am
hi i have uncompressed the files with winzip and extracted the rar files with winrar so i get files with the extension of .bin and .fw the firmware i have opened with s1res is showing me the images that look the same from 9.0.43 upto 9.0.50 but i get an error message invalid firmware file.
many thanks for the replys
jason
Old 22nd Aug 2007, 5:29 pm
jas1uk20012002 , if that's the case, try uninstalling and re-install various other versions of MP3 Utilities. Some versions would give an error during flashing.
Old 23rd Aug 2007, 11:18 am
thanks for replying and being paitent lattesurf with me i tryed other versions of mp3 upgrade tools and i was still getting the same error message so i tryed shorting the pins again and now i get sucsesfull upgrade program will exit message. but still not a working mp4 player but at least im now getting a white screen and its in my computer as f drive now.
little update i have flashed (B806G6V1.7_2006-10-16_9.0.48.fw) to my player and it sort of works on startup i can see it say welcome but its spelt backwards and the colour is all mixed up and only bottom half the screen the top half of the screen is still white it loads to what looks like the connection between the player and pc but i can only make half of it out.
do i have to flsh it twice as in firmware first then a bin file after or are these the same files.
many thanks
jason
Old 23rd Aug 2007, 4:56 pm
jas1uk20012002 , for the v9.0.xx series, usually you'll just need 1 firmware file as most of them available are full firmwares.
The problem you are experiencing would likely be due to the display driver for the screen being incompatible with your player. The only solution is to keep trying..
firmware Samsung 652 ATJ2091N Guz Dead Players 4 17th Dec 2010 4:29 pm
Looking for firmware SAMSUNG 722 K9G8G08UOM ATJ2091N skizzetti Firmware 6 2nd Dec 2008 5:01 am
Looking for firmware ATJ2091N - SAMSUNG 710 Reyclay Firmware 1 13th May 2008 9:23 am
Looking for firmware ATJ2091N SAMSUNG 707 1GB salarsat Dead Players 12 19th Mar 2008 3:29 pm
Looking for firmware atj2091n samsung 722 medhypere Dead Players 0 4th Jan 2008 10:29 am
