firmware Samsung 652 ATJ2091N
Old 18th Aug 2007, 4:45 pm
Guz Guz is offline
Default firmware Samsung 652 ATJ2091N
hi all plz i need this firmware for my mp4 its a nano clone
1G
Smasung 652
k9g8g0800m
ATJ2091N
(2006.12.25)
what need to open files ( .RFW ) i found a firmware with this format
many thnx
Old 18th Aug 2007, 7:34 pm
Guz , i've not seen a .RFW extension before, so not sure what it does. i'll suggest that you try opening it with S1res and see if can be loaded, guide here http://www.mympxplayer.org/how-to-mo...ool-vt206.html
You might need to rename the file extension to .FW to allow the S1res tool to open the file.
If it can be opened by the S1res tool, then try flashing it into your player, guide here http://www.mympxplayer.org/how-to-up...ayer-vt46.html
You might need to again rename the extension to .FW
Old 18th Aug 2007, 7:52 pm
Guz Guz is offline
i cant open this firmware =(
Old 19th Aug 2007, 12:41 am
Guz , then it possibly is not a firmware file. What i'll suggest would be to try the various v9.0.xx firmwares until you get a working one here http://www.mympxplayer.org/actions-9...mare-dc37.html
Flashing guide here http://www.mympxplayer.org/how-to-up...ayer-vt46.html
Good luck.
Old 17th Dec 2010, 4:29 pm
i have one like this very similar but i have a samsung 704 chip,i tried every actions 9xxx fw but none work i learned to cut my losses on my dead player
Looking for firmware SAMSUNG 722 K9G8G08UOM ATJ2091N skizzetti Firmware 6 2nd Dec 2008 5:01 am
Looking for firmware ATJ2091N - SAMSUNG 710 Reyclay Firmware 1 13th May 2008 9:23 am
Looking for firmware ATJ2091N SAMSUNG 707 1GB salarsat Dead Players 12 19th Mar 2008 3:29 pm
Looking for firmware atj2091n samsung 722 medhypere Dead Players 0 4th Jan 2008 10:29 am
firmware for atj2091n samsung 710 jas1uk20012002 Dead Players 7 23rd Aug 2007 4:56 pm
