USB connection screen appears for few second
Old 21st Aug 2007, 12:42 pm
Default USB connection screen appears for few second
I have a 2gb s1 mp4 player having F/W 3.5.7.It used to work absolutely fine till i started facing this problem:
When i connect my player via USB, it is not at all detected on my PC; However it's not dead coz it starts normally with the hourglass followed by the startup screens & then the USB connection screen appears for only a second & proceeds to the menu.It is also not getting charged via USB.So i cannot transfer music/etc.Plz help
Old 21st Aug 2007, 2:25 pm
I think the battery connections got broken somehow, or the battery is dead.
Pop it open and check the connections, if they are broken re-solder them, else get a replacement battery.
Old 21st Aug 2007, 7:08 pm
i've done as u said, but this still doesn't help!!.I will have to try it out on ma friendz PC.Thnx
Old 21st Aug 2007, 8:25 pm
linc_freak123,
Can you use your player normally when UNPLUGGED from your PC?
It could be the USB cable or the USB connector on your player that might also be the problem. If you can find a spare USB cable, try that or try different USB ports on your computer too.
Also, try connecting your player into another computer as well to see if that helps.
Old 26th Sep 2007, 9:47 am
replace USB cable!
Blank screen appears tosemusic Support and How To 1 28th Dec 2008 2:04 am
screen appears blue with timer when i switch my mp4 on crasymama Dead Players 2 1st Jan 2008 9:04 am
mp3 screen connection Edgaras Support and How To 0 2nd Nov 2007 11:51 am
When I try playing AMV files on mp4 the grey screen appears Dima Video related 5 4th Dec 2006 1:23 am
Only blue screen, no connection!!! JanoH Dead Players 8 5th Oct 2006 7:49 am
