No Sound
Old 24th Aug 2007, 7:06 am
Default No Sound
Everything works - music, video... but no sounds comes from either of 2 headphone sockets. Have tried different headphones - same result.
If connected to the PC and songs are played, the sound is o.k. on the PC speakers.
Memory: Samsung K9K8G08U0M
Software:
acts16D_16_szg
Version: 3.5.37
Any ideas?
Old 24th Aug 2007, 8:36 am
rippedoff , try a firmware extraction, repair, and re-flash.
Extraction and repair guide here http://www.mympxplayer.org/how-to-ex...tool-vt66.html
Re-flash guide here http://www.mympxplayer.org/how-to-up...ayer-vt46.html
See if this solves the problem. If not, likely either some component is damaged or missing in your player.
Old 28th Aug 2007, 4:04 am
Thanks for the advice.
Tried your suggestions - but still no sound!
(what is puzzling is that BOTH headphone sockets are affected, thus ruling out anything to do with a loose connection on one of the sockets).
No sound after AMV convert pr_wainwright Video related 1 28th Jun 2007 12:54 pm
sound jtaiariol Support and How To 6 28th Nov 2006 6:33 pm
No Sound!! haseebanjum Support and How To 4 19th Sep 2006 6:33 pm
Bad Sound with 4.00 Bad Visual with 3.68 Eks Bee Support and How To 2 12th Jul 2006 4:48 pm
AMV sound antdroide Video related 2 11th Jun 2006 2:55 am
