Help me now !!! My Player is dead
First, Thanks for to Reply !
I have a mp4 Player :Lisong (Wilson co.,ltd) Firmware ver: LSD 9112_20 2006_10_21 9.0.50 I try upg...my Player then my screen is white .I shutdown my player = "play" key then Start ="play" key .Screen of my Player .... eg: http://n.domaindlx.com/VitaminB1/1.JPG Please tell me to fix it ~ thanks !! |
oh lol..this is quite a weird...inverted screen??..but y did u upgrade ur player??i think that ur player firmware version is v9 series..v9 series could not be upgraded right now..maybe lattesurf can solve this
caohuuvuong , the firmware you have flashed in is not compatible with your player. The screen driver is different for your screen's hardware, hence the screen is inverted.
What i'll suggest is to try all the v9.0.xx series firmwares. But if non-work, then perhaps you have no choice but to use back this firmware which is inverted. Does the player function properly with the screen inverted? Like playing music, videos, FM radio, etc? |
| All times are GMT -7. The time now is 5:56 pm. |
