Need help with 4gb meizu M6 SP Version
Old 27th Aug 2007, 9:20 pm
Default Need help with 4gb meizu M6 SP Version
It has only a white screen due to an unsuccessful firmware upgrade. I finally have it being recognized by my PC but it still has only the blank white screen. It now shows up under mycomputer as a f: drive and I can access the players folders and even hear the clicker sounds now.
I guess I'm not understanding how to put the resource.bin file into the player or something for the last step. Meizume.com and/or en.meizu.com has no support what so ever for this product. Any help would be appreciated. Thanks!.
Pocket_Nano
ChiPod's Rule!
Old 27th Aug 2007, 10:22 pm
http://www.meizume.com
this site has all you need to know for the white screen problem - you may need the DFU tools available on the site, use the search function and you should find a solution
Old 27th Aug 2007, 11:32 pm
Pocket_Nano
The original version of the M6 used a Toshiba LCD and was called the TP version. Meizu later changed to a Samsung LCD, SP version. If your player is less than about 8 months old it will most likely be an SP version. A white screen after an update usually indicates that you have loaded a TP version firmware onto an SP version player and the LCD drivers are not compatible. Reloading a full SP version firmware (2 files, M6.EBN & resource.bin) and you should be ok. To confirm which version your player is check the serial number on the back, it will either start M6TPXXXXX... or M6SPXXXXX... The different version firmware are labled S2.0023 of T2.002.3.
Old 28th Aug 2007, 8:43 am
That site has a lot of people with the white screen problem but only very few who have got lucky and fixed it. I already know about the DFU Tools that's how I got to the steady white screen instead of just the white flash it was doing.
ChiPod's Rule!
Old 28th Aug 2007, 8:50 am
Pocket_Nano
I know what version it is thanks!. It is the SP version like it says in the topic of this post. "NEED HELP WITH SP VERSION". But I am at the point where now I have a steady white screen and can access the player and it is recognized by my PC but after using DFU Tools to upload the new firmware it finishes then when I unplugged and try to turn it back on for it to say upgrading or add resource file nothing of this is happening it just does nothing. And yes I am using a SP Version Firmware. Any other suggestions Tadad1? Thanks!.
Pocket_Nano
ChiPod's Rule!
Old 29th Aug 2007, 10:22 am
Default Re: Need help with 4gb meizu M6 SP Version
"BUMP"
ChiPod's Rule!
Old 29th Aug 2007, 11:47 am
Try using an early version of the firmware with the DFU Tool, S1.009 or S1.010
Old 30th Aug 2007, 7:11 pm
Already tried that. Still nothing!. I'm very disappointed with Meizu's support and lack of tools for this problem.
ChiPod's Rule!
Old 30th Aug 2007, 7:39 pm
Going back to your first post, can you still connect with your PC and access the player?
Does it turn on and off?
Was there a problem with the player prior to update?
It also seems that the DFU tool may have some compatibility issues with certain PC's\Motherboards etc. If you have accces to another PC that may be worth a try.
Old 30th Aug 2007, 7:53 pm
It is recognized by my PC as a USB DFU Device and I can not access the players drive anymore. It does not turn on and off it only blinks a white flash for a split second when I try to turn it on. There were no problems that I know of prior to it messing up. I purchased it for my 12 year old daughter it worked for 3 days then she brought it back to me this way. I don't even think it's from trying a firmware upgrade because she doesn't even know what that is.
ChiPod's Rule!
Where to buy Meizu M8 ?? mac_gyver General Discussion 18 12th Mar 2009 11:32 pm
Meizu vs everything else Th3_uN1Qu3 General Discussion 4 4th Jan 2008 2:03 pm
meizu willyhehe92 General Discussion 5 4th Aug 2007 7:19 am
Where to buy meizu M6 lite General Discussion 7 25th Mar 2007 1:50 am
meizu clone? chriroz General Discussion 8 12th Feb 2007 1:42 pm
