Need firmware for sunplus SPCA536
Old 2nd Sep 2007, 9:21 am
Default Need firmware for sunplus SPCA536
I have a Best Buy Easy Player PMP Flash, based on the Sunplus SPCA536 chip (without camera or fm) and I uploaded the wrong firmware using the tool included in the CD, so the player died.
Searching the Internet, I learned that by shorting the pins 28 and 34 of the SDRAM you can put the player in a state that you can upload a firmware in MASK-NAND mode. I have tried a couple of firmwares I found, but none works. The closest to work was the one from the french device ntg1. With it, my device was able to turn on and the screen showed some icons and I was able to navigate through them, although the icons on the screen seemed bigger and reversed and I was not able to play or read anything.
I have searched these forums and there doesn't seem to be a solution for Sunplus based PMPs, but I thought I could still give it a try asking again...
Old 2nd Sep 2007, 6:53 pm
fizban , the problem with these Sunplus players are that there are no firmware extraction software on the internet (none that i know of). So it is quite difficult to locate a firmware.
The best solution is if your player is still under warranty, then contact your seller for an exchange.
Old 4th Sep 2007, 10:22 pm
Default Re: Need firmware for sunplus SPCA536
The player is no longer under warranty... And the manufacturer doesn't want to send me the original firmware.
Anyway, I have tried the neonumeric ones:
Firmware for NTG-1 with no FM
Firmware for NTG-1 with FM
And the NEC ones
PMP101 firmware
PMP103 firmware
PMP103C firmware
Unfortunately, none of them worked for me.
Old 23rd Oct 2007, 9:37 am
hi you talk spanish?, I need help please, I have the mp4 and, I can connect to the computer, I need a photo of memory , please, you can help me?.
Hola como va espero que bien bueno te escribo para decirte que tengo el mismo mp4 y quiero saber si puedes poner una foto de la memoria que dices segun parece es el mismo reproductor que el tuyo y no puedo ponerle ningun firmware, me ayudarias?, estoy desesperado por que necesito vender el aparato por una urgencia que tengo desde ya muchas gracias, un abrazo desde argentina.
geronimo
Old 22nd Dec 2007, 4:23 pm
Hey i think i may be able to help if you are able to upload firmwares to your player, i got this software with my player I'm not sure i it will help.
http://www.mympxplayer.org/uploads-by-members-dc20.html
It should appear in that section after Admin have allowed it to be uploaded.
I also have a sunplus player but will not work, i tied shorting the pins but nothing the player just cuts out and restarts, any ideas?
Old 13th Jan 2008, 3:18 am
Just for future reference, I managed to sort of resurrect the player by using the NTG-1 firmware. All the menus are reversed, like if you were looking them through a mirror, and the images do not fit the screen. The buttons do not match the original (e.g. the power button is used to select a menu option), but at least I can use it as an mp3 player... If someone finds a firmware that fits better, please post a reply.
Old 27th Feb 2008, 11:26 pm
hey can u help me???
my jxd 661 pmp is absolutely dead.
u can also read the post on my player i have posted the problem there.
the thing i s i am not even able to switch on the player
Old 28th Feb 2008, 2:09 am
Hello
fizban could You tell me how to upload new firmware to my dead player?
I short pins on SDRAM and I can hear that Windows recognize my player, but what should I do next?
Old 28th Feb 2008, 4:50 am
Originally Posted by filon1312";p=&quot View Post
Hello
hey just install the player using its drivers.and the use the same upgrading tool which u used before to upgrade a new firmware.but this time make sure that u r upgrading the right firmware.
Sunplus SPCA536 dead player repair guide paulareno Dead Players 1 23rd Feb 2009 7:51 am
Sunplus SPCA536: I've got one, interested in fiddling. yyttu General Discussion 26 6th Jul 2008 6:58 am
timetop dc270t sunplus spca536 nguga Dead Players 3 28th Mar 2008 6:18 pm
Looking for firmware: SUNPLUS spca536 sirAlex Dead Players 2 22nd Dec 2007 4:30 pm
Sony NW-T8 (fake)...sunplus spca536 with cam 256MB flash danilom Dead Players 1 16th Dec 2006 1:11 am
