Need Firmware for: AK1025 - Samsung722
Locked MP3/MP4 Player (Fake 8G, real 512M)
CPU: AK1025 Flash: Samsung 722, K9g4g08u0a PCB (on back): IS91B11 V0.4 Anyone can dump this model firmware? Tia |
PietroDVB , the AK* chipsets would be using the newer v9.1.xx firmwares, which at the moment is not supported by the firmware extraction tool. If your player is working properly, i'll suggest that you do not do anything to the firmware and just enjoy it as it is.
Re: Need Firmware for: AK1025 - Samsung722
Thank you Lattesurf. So do you know when it can be aviable? I have an AK1022 do you know if it don't work too?
Snec , we don't know when the new firmware extraction tool would be ready. There is currently only 1 person that i know of (wiRe) who is working on the Actions chipset tools. But probably he has stopped working on it, i'm not sure.
Anyway, if it is available, you'll be able to find it in here. |
AK1025 is counterfeit of Actions chipset.
Thank you for your reply.
I try to upgrade my mp4 with the "Glacier_9.1.51" from http://www.mympxplayer.org/full-firm...res-df652.html and now it's work as an flash hard drive (you understand?) and the screen is white so i can't see any menu. Sorry for my poor english ... :roll: |
Snec , the firmware you flashed in is not fully compatible with your player. The LCD driver probably is different, causing the white screen. You'll need to keep trying other firmwares.
OK! Thank you sooo much Lattesurf!!!! I hope to find the good one ^^
| All times are GMT -7. The time now is 6:26 pm. |
