Need Firmware for chip Samsung ATJ2091N
Old 18th Sep 2007, 10:11 am
Default Need Firmware for chip Samsung ATJ2091N
I have my MP3 player dead, because overwrite his original firmware.
Only I have the chip model and the code of the board:
Is a MP3(DVR)
Capacity 2GB, no FM.
Chip Samsung: ATJ2091N
Board serial: SCC91-001 MAIN v0.2
2006.09.19
I don't know what FW I can use. I hope answers, and sorry for my bad english..!
Old 18th Sep 2007, 6:39 pm
lsizquierdo , your player would be using the v9.xx firmwares here http://www.mympxplayer.org/actions-9...ware-dc37.html
As there is no way to tell which firmware would work with your player, you'll need to try all of them until you get one working.
Old 18th Sep 2007, 9:05 pm
Default Re: Need Firmware for chip Samsung ATJ2091N
It's that I thing but my player perhaps use a chip ATJ2091N without FM and a Memory Sansung of 2GB, is only a MP3 player whit a monochrome display with backlight of 7 colours, is a generic player, and the 9.x.x.x FW series almost all were made for MP4 players.
I need the firmware that can handle this chip but it adjust to this display..!
Old 18th Sep 2007, 9:13 pm
lsizquierdo , in this case, you'll find more suitable firmwares for your type of player at the S1mp3 forum here http://www.s1mp3.org/en/downloads_fw.php
But however, it seems that the list are mainly the v3.xx firmwares. Not very sure if they have updated their list to include the v9.xx firmwares.
Old 19th Sep 2007, 3:18 am
1. 128*32 black and white screen solution
2. Wire control buttons
3. Power supply: AAA dry battery
4. Audio format supported: MP3/ WMA/ WMV/ ASF/OGG/ WAV / ACT. (APE
not supported)
5. DRM supported, needs plug-in RTC- HT1381
6. EQ supported: Normal/Rock/ Pop/ Classic/ Soft/Jazz/ DBB
7. SRS: supported
8. Video: not supported
9. DC: not supported
10. Recording format: MP3/WAV/ ACT
11. Recording source: MIC/FM IN
12. FM: supported
13. Picture: not supported
14. E-book: not supported
15. Program space: 5M Bytes
16. Flash: new architecture flash driver, 4G Bytes supported
17. Card: not supported
18. Directory level: 8 level
sub-directory supported
19. File number: supports 999 files at most in single directory
This official Actions solution for 2091N IC. If you want the official firmware I request.
Looking for chip ATJ2091N - Memory SAMSUNG 646 inniyah Firmware 2 7th Jan 2010 12:45 am
Samsung 625 K9L8G08U0M chip and a ATJ2091N chip. bimbour1 Dead Players 0 28th Oct 2009 7:25 am
Looking for firmware ATJ2091N - SAMSUNG 710 Reyclay Firmware 1 13th May 2008 9:23 am
Looking for firmware: chip: ATJ2091N killah Dead Players 2 24th Sep 2007 5:32 pm
Firmware for Mp4 - Chip: Atj2091n, please? Ryman General Discussion 1 20th Aug 2007 10:58 am
