Need Wilson 9.1.52 F285 FULL Firmware PLEASE
Old 18th Sep 2007, 7:23 pm
Default Need Wilson 9.1.52 F285 FULL Firmware PLEASE
Please if you can help me, I have blue screen ..
Old 18th Sep 2007, 7:36 pm
amyr , there is no use trying to extract your firmware using S1fwx, as currently it only supports upto v9.0.43, your player is using v9.1.52.
This also means that you'll have a problem of locating a suitable firmware as others are unable to dump their firmware for you to try.
You have 2 options, the easiest would be to contact your seller for an exchange if it is still under warranty.
Or, you can try flashing all the v9.xx firmwares one by one until you get a working player, list here http://www.mympxplayer.org/actions-9...ware-dc37.html
Old 19th Sep 2007, 3:04 am
Default Re: Need Wilson 9.1.52 F285 FULL Firmware PLEASE
Need chipset model and also LCD model is preferred.
Old 19th Sep 2007, 3:14 am
This is what I read when I opened it :
ATJ2091N
FB15DB1BQ
I have tried almost every v 9.xxx firmware but nothing, the only thing i get is a blue screen
LCD : 1.5
Does anyone has S1clone image for this type of player
Old 19th Sep 2007, 3:22 am
Is it CSTN, TFT, or OLED display?
Actions does not provide an official solution for 2091N with a color screen. You will have to use 2091N ACTOS core with appropriate driver for your display.
Old 19th Sep 2007, 3:27 am
It is 1.5 inch 65536 true color OLED screen. What should I do next...
Old 23rd Sep 2007, 9:03 pm
ATJ2097 official solution has 160x128 OLED screen.
Firmware for Lisong mp3 Wilson and co ver 9.1.53 James007 Firmware 1 18th Feb 2009 6:43 pm
Looking for firmware wilson F285 ver 9.1.52 cchl2005 Dead Players 2 11th Nov 2007 2:37 am
FULL Firmware Wanted! Lisong Wilson 2GB LSD 9.0.48! null6 Dead Players 0 9th Jul 2007 10:42 am
I need Firmware for xio ATJ2091N for Wilson.co.ldt 2G fran20es Dead Players 2 23rd Feb 2007 1:32 am
FirmWare sm1p3v3_2_1_6.bin from Wilson Co.ltd XamleTT Dead Players 13 11th Jun 2006 7:18 pm
