-   -   Help white screen after fwring on a s1 mp3 wilson x.x (http://mympx.org/forum/dead-players/39064-help-white-screen-after-fwring-s1-mp3-wilson-x-x.html)
lattesurf 20th Sep 2007 6:03 pm
glas , you can try to flash the backup dump with S1clone, more info here http://www.stud.uni-karlsruhe.de/~uw...?Tools.s1clone
However, it is currently not fully tested, so it may or may not work for you.
glas 20th Sep 2007 6:43 pm
no way i did it
and it says that the mp4 its different some like that
of the bios and shit like that
u.u
i dont have anymore ideas
im desperated
T.T
lattesurf 20th Sep 2007 8:23 pm
glas , probably you might have come to a dead end.
The main problem lies in that the extraction tool doesn't yet support the newer versions. So chances that you'll find a compatible firmware is lower, unlike the v3.5.xx firmwares which have many in the downloads section.
glas 30th Sep 2007 4:23 pm
dudes
i tried everything
even copying another identical mp4 to this one and the program gives me an windows error
how i can be that no one here has that file?
>u<
u.u
lattesurf 30th Sep 2007 7:51 pm
glas , S1clone has not been fully tested yet, and works for some and not for others.
glas 18th Dec 2007 12:31 pm
some one know if it arrive a new versioN?
