Problem in MP4/iPod (Firmware not found!)
Old 20th Sep 2007, 11:15 am
Default Problem in MP4/iPod (Firmware not found!)
Hello…
good, as all can see, I am of Brazil and I am with problems in my MP4/iPod
The photos of it are here:
http://img514.imageshack.us/img514/8314/mp4yj1.jpg
http://img481.imageshack.us/img481/3258/mp42hb7.jpg
I am looking the FIRMWARE of it!
I have the following data:
LKC_7517_01_01L
2007-06-11
9.1.50
2005-01-09
Please, they alguem has the Firmware of this device?
I am with difficulty of finds it!
I am thankful since now!
*EDITED
More information…
Great Chip:
“Sansung 719
K9LAG08OU0M
PCB0 "
Small Chip:
“ACU7503
G2023CA 528 "
Chip still has one lesser, more believes that nao makes difference!
If to need it to only ask for!
I wait anxiously!
Old 20th Sep 2007, 8:25 pm
BrotherArthur , i'll suggest that you start trying all all the v9.xx firmwares here http://www.mympxplayer.org/actions-9...ware-dc37.html
As there is no way to tell which firmware is suitable for your player, you'll need to try all of those for your screen size (from your pictures, looks to be 1.8") until you get a working firmware.
Old 21st Sep 2007, 10:00 am
Ok…
already I tried varios, I must you ones 500mb of firmwares in my computer, more as?
former: I install one firware, exactly that the error occurs, I detach player of the USB and try to bind? to see if he functioned?
in all firmwares?
or to function certain goes you that to make I precease it whole number, without giving no error?
Thanks a lot "lattesurf"!!!
*EDITED
Another thing, I know that formware that it was in the device is the 9.1.50!
it can if that some firmware as 9.0.50, 9.0.48 functions correctly in my player?
I wait reply!
Arthur TBA
The user of Brazil!
Old 21st Sep 2007, 6:59 pm
BrotherArthur , i'm not sure if I understood you fully.
But what you should do now, is to download all the available firmwares (which you have already done), and start flashing them in one by one using MP3 Utilities Upgrade Tool.
You'll need to keep trying one by one until you get a firmware that restores your player to a working state.
You can always try other versions even though the original working firmware was v9.1.50. There are other members who recovered their players and used a different version from their original version.
However, do note that the current firmware extraction tool only supports upto v9.0.43, so other users are unable to dump their firmware for you to try. You might face a problem of not locating a suitable firmware eventually.
Old 22nd Sep 2007, 5:02 pm
Ok…
thanks a lot lattesurf!
I go to try all firmwares of the section 9.x.xx
if to obtain acknowledgment here!
Until there, I am in the wait of that some user has firmware the same that mine and thus he can make upload for me!
“The hope is finishes it that it dies”
Thanks...
Arthur TBA
The user of Brazil!
Old 8th Jan 2008, 2:40 am
Folks, I am still with the same problem ...
Does not yet found this firmware?
I thank everyone who helped me
Arthur TBA
The user of Brazil!
Old 3rd Jul 2008, 3:34 pm
http://www.s1fw.com/Help/Details-fir...-Category.html
LOOK FOR
Made in Shenzhen
Dead player
Problem with Black color Fake Ipod Nano Looking for firmware Tunan Firmware 2 17th Aug 2008 8:04 am
Found firmware SPCA536 (Probably) filon1312 Dead Players 7 28th Feb 2008 12:36 pm
found site with firmware littleandi Firmware 0 18th Feb 2008 1:03 pm
Fake iPod firmware problem ...... Stvol16E Dead Players 0 21st Dec 2007 2:56 pm
Skinning my MP4 using firmware 9.1.52 i found on net TaranQ Support and How To 3 13th Dec 2007 10:37 pm
