problem whit my PMP
Old 25th Sep 2007, 5:39 pm
Default problem whit my PMP
Hi... i need help whit my PMP... I'm from Argentina, so i hasn't got a good English... I'm goingo to try explain my problem... after connect to the computer for some changes, when i disconect it, it stop working...
http://img216.imageshack.us/img216/2819/foto1wf3.th.png
this is it... when i turn on it, it stay like the photography, I remain labeled
so i need a new firmware for a samsung 722 k9g8g08u0m, thas the chip, and it has an other chip sunplus spmp3050a-hl171 ... i hope you can help me, because here anyone could help me. what firmware i need??? can you give me a link???... i hope i could explain me
Old 25th Sep 2007, 7:20 pm
nomercy , unfortunately there are no available Sunplus tools for extracting firmware, so there really isin't firmware available. What i'll suggest would be to contact your seller if it is still under warranty.
Old 26th Sep 2007, 8:15 am
Default Re: problem whit my PMP
I have a small problem with that… my aunt bought it in Chile… and i can't communicate with the seller… can i do a backup to the firmware, delete all in the pmp and try to put several firmware in it until find one that works???… and if it doesn't work...is it possible to repair it?(the firmware).i mean the backup
Old 26th Sep 2007, 7:06 pm
nomercy , there is no way to backup the firmware from your player as there are no tools available for it (none that i know of).
Old 27th Sep 2007, 9:14 am
so it is dead... and what i can do with it??? drop it??? use it like a target and shoot to it??
Old 27th Sep 2007, 9:29 am
i have found a person how has the same pmp or identic... can y do a backup to her firmware and put it in my pmp
Old 27th Sep 2007, 7:52 pm
nomercy , i have already said twice that there are No tools available to extract to the firmware. Most Sunplus players need to be factory reseted, so i'll suggest that you contact your seller for an exchange if it is still under warranty.
Old 17th Dec 2007, 11:38 am
hola yo tmbn tengo este reproductor, lamentablemente no te puedo ayudar xq todabia no hay algun programa para hacer un backup del mp4 ...
lo que he encontrado es esta pagina:
http://www.usb-mp3.com/download/files/M780.rar
y este seria el manual
http://www.usb-mp3.com/download/file...060419M780.pdf
viene en chino...
aqui esta en frmware original de un reproductor llamado M780 de Newsmy el cual es exactamente igual al nuestro por afuera, no se que procesador tiene...
pero quiero preguntarte si él antes reconocia más de 512 canciones, y si el firmware q te pase sirve y trae radio, es q el mio aun funciona y no he hecho la prueva
Is possible to put fw 9.x.x to device whit 3.5.37 android General Discussion 1 8th May 2009 12:41 am
Onda VX858 LE problem whit RKL Logo Edit fortissimo91 Mods and Themes 3 30th Oct 2007 9:35 am
ONDA VX858LE problem whit video fortissimo91 Video related 0 15th Oct 2007 6:53 am
NEED FIRMWARE FOR NANOCLONE WHIT ATJ2098H AND SAMSNG 643 botti Dead Players 0 5th Jan 2007 11:00 am
