-   -   Help please Ipod nano clone dead 1.5in ATJ2085H (http://mympx.org/forum/dead-players/39185-help-please-ipod-nano-clone-dead-1-5in-atj2085h.html)
alrs71 29th Sep 2007 5:54 pm
I need some help please recovering the missing firmware.
After more than a year with this Ipod clone dead, I am still missing the correct firmware. Lots of firmwares I have tried, and none of them worked and I am feeling very bad. I have lost all hope.
But well, I trust in you, because I have seen from may posts, that you have recovered many mp4's.
Ok.
Here are my Ipod nano "black" clone specifications:
Chip: ATJ2085H
Memory: Samsung 410
K9F1G08U0M
YCB0
(I dont remember the memory capacity, but I beleave is 2 or 4 gb.
Chipset: MP-693C-SL MAIN V1.3 2005.1214
LCD: 1.5in
No FM radio.
And other thing. I says iPod (with the apple) at the front and at the back.
lattesurf 29th Sep 2007 8:14 pm
alrs71 , the Samsung K9F1G08U0M is a 1Gigabit (128 MegaByte) chip, it's not 2GB or 4GB.
The only way to recover a dead player is to try each and every firmware for your screen size. i'll suggest that you try both the v3.5.35 and v3.5.37 firmwares here
v3.5.35 http://www.mympxplayer.org/actions-3535-dc15.html
v3.5.37 http://www.mympxplayer.org/actions-3537-dc16.html
alrs71 29th Sep 2007 9:05 pm
Re: Help please Ipod nano clone dead 1.5in ATJ2085H
Wow thanks for that. But now I have another question. Wouldn't it matter the Chip and Chipset of the mp4?
And also. When I try to update the recovery bin file, once it beggins loading the bin, it appears me a sign with the following: "Unable to upload bin file, please check if it is connecting. The program will exit. Please check if you mp3 is correctly connected.": And it is well connected.
Or, it appears me: "Flash not recognized, or Unknown Flash volume, or your Flash is protected, Unable to write)" (something like that).
Y have reseted several times the mp4, beleaving it will work now, but it doesn't.
Also, when making a short circuit to the memory, the screen sometimes turns on and sometimes don't.
