HELP!!! QUICK!!
:cry: IM IN BADLY NEED OF THE CORRECT FIRMWARE FOR MY PLAYER!!
SUMBODY HELP ME PLEASE!! DOES ANYONE KNOWS WAT IS THE CORRECT FIRMWARE FOR THIS?? ->samsung 649 K9G8G08U0M ATJ2093H ->i dont know my screen size but its an imitation of ipod. |
yeojharaz , your player would be using the v9.xx firmwares here http://www.mympxplayer.org/actions-9...ware-dc37.html
As there is no way to tell which firmware would work with your player, you'll need to try all those for your screen size until you get a working one. However, as the firmware extraction tool currently only supports upto v9.0.43, you might have a problem of locating a suitable firmware. Good luck. |
| All times are GMT -7. The time now is 1:29 am. |
