how do i find out my firmware? (pics of player inside)
Old 8th Oct 2007, 5:17 pm
Default how do i find out my firmware? (pics of player inside)
hi all, i turned on my player earlier and all i get is a blank white screen. if i press the buttons i can still get music to play. also it gets extremely hot at the side of the screen. I need to know what firmware i need and what software do i use for firmware upgrade? here are some pics:
Any help greatly appreciated, Thanks!
Old 10th Oct 2007, 12:58 am
give me some better pics.
and use google and type your serial number.
than u can see what player it is and what firmware u need.
Old 20th Oct 2007, 3:36 am
I think I have the firmware for this player.
Did you change the firmware or did this happen all by itself?
Old 20th Oct 2007, 9:45 pm
sam36 , open the player to check for any short circuits. The heat you mentioned is not normal, and likely might be some short circuit.
Old 26th Oct 2007, 6:20 am
open the player's cover. clean any unusual thing found on the LCD pins. re-solder the pins. cover the pins with tape.
Old 26th Oct 2007, 9:40 am
Could it be that a short circuit put "blank" the screen... beside of wrong firmware I mean
Old 26th Oct 2007, 8:53 pm
DaremoS , it is very likely. Perhaps some signal/data pin for the screen got "shorted" and resulted in a blank screen.
"Hot" players generally mean either a short circuit somewhere, or a damaged battery.
Old 17th Dec 2007, 3:08 pm
Default Re: how do i find out my firmware? (pics of player inside)
Hello Riolist,
can you send me the firmware of this 2,4"-Player?
I have the same dead model and need a firmware.
thanks
A picture of a 4GB chip inside a player ashley_rb General Discussion 2 26th Apr 2007 8:20 am
Inside my cheap ebay player cziepe General Discussion 4 17th Apr 2007 8:30 am
HELP, i need firmware for TPOD NEO 1 Go (photo inside) fitigre38 Dead Players 0 22nd Dec 2006 7:51 am
Dead player all specification inside... Bronco Dead Players 1 13th Oct 2006 7:05 pm
[NEED FW] NO Nano-like player!! Look pic inside, thanks!!! Remoz Dead Players 0 1st Aug 2006 1:26 pm
