big mistake flashing onda 858le any possible help
Old 19th Oct 2007, 7:47 pm
Default Re: big mistake flashing onda 858le any possible help
done that but it just goes back to the charging screen
Old 19th Oct 2007, 7:55 pm
Has it been doing this all along? Because you only mentioned it two posts ago. It's important that you provide accurate and complete information, you have to realize that it's difficult to help someone blind like this, and information is the only thing that lets us 'see' what's happening with your player. From now on please try to be as accurate and complete as possible.
With the power off, try plugging it into a usb charger (NOT the computer) then unplugging it.
Old 19th Oct 2007, 8:04 pm
sorry yes the charging icon comes on all the time when i hold down the off button,tried pluging the charger in the wall socket and it just does the same icon goes up and down,then i pluged it back in to usb port on my laptop and it says usb device not recognized
Old 19th Oct 2007, 8:17 pm
a m8 of mine said try unbatu live cd so i pluged in the unit put it in to usb mode and it comes up rockchip usb mp3 and rockchip usb sd dont know if its any help
Old 19th Oct 2007, 8:18 pm
for the second time, does it have an actual on/off switch, that is, a slide switch that has discrete 'on' and 'off' positions, or is it just a single momentary pushbutton that you press and hold to turn the player on and off?
Also, have you downloaded and installed the new version of the updater? And do you know which folder it installed to? Before you do anything else, please do that, and know which folder it installs to (which may be different from the one you downloaded to, if you don't understand this, ask). Go to that folder and identify the correct driver, it's in a folder that mentions windows XP.
  #16 (permalink)
Old 19th Oct 2007, 8:19 pm
I don't see how it can be since the updater program only works under windows.
  #17 (permalink)
Old 19th Oct 2007, 8:21 pm
all i did was plug in the usb and put the player in to usb mode and thats what the drives showed as under that os
  #18 (permalink)
Old 19th Oct 2007, 8:25 pm
That's fine but you can't do anything to restore your player with Unbuntu because the updater program won't run under that os, it only runs under windows. The goal is not to get your dead player recognized, it's to update the firmware to the correct version, and that can only be done under windows.
  #19 (permalink)
Old 19th Oct 2007, 8:33 pm
really dont know where to go now
  #20 (permalink)
Old 19th Oct 2007, 8:57 pm
If you want my help you can answer my questions. Just a suggestion.
Big problems with hacked 16gbs Onda clone (?). Cant low level format or flashing it!! W4XiM3 General Discussion 2 28th Oct 2009 11:10 pm
FM radio reception on my Onda 858LE bishy96 Support and How To 1 16th Dec 2007 5:11 am
ONDA 858le MP4 - what converter software to use? ben2001 Video related 3 2nd Dec 2007 8:32 pm
ONDA 858le MP4 help ben2001 Support and How To 3 29th Nov 2007 12:21 pm
Wrong flashing ONDA VX858LE heat666 Dead Players 12 24th Nov 2007 8:31 pm
