-   -   big mistake flashing onda 858le any possible help (http://mympx.org/forum/dead-players/39387-big-mistake-flashing-onda-858le-any-possible-help.html)
paul01609 19th Oct 2007 9:02 pm
yes m8 i really do need the help and im glad your helping me to try and sort it,is it possible to get the drivers for the firmware i loaded on to it?when i click on the unkown device says the correct drivers are not installed or not needed
Riolist 19th Oct 2007 9:28 pm
Ok, i'll try. For the third time, does the player have an actual on/off switch or just a button?
For the second time, have you downloaded the latest updater from this site, installed it, and located the usb driver that is found in the install folder?
paul01609 19th Oct 2007 9:59 pm
Re: big mistake flashing onda 858le any possible help
yes it has a on off witch i tried holding in back for a few seconds to see if it would shut down but wont,i have also down loaded and installed the update file
Riolist 20th Oct 2007 2:57 am
Have you located the install folder and identified the correct usb driver? It's in the folder titled 'RockUSB Driver(2k,XP,2003)'?
paul01609 20th Oct 2007 8:25 am
sorry m8 had to go to bed it was 6am and i was satterd,i havent looked in the rockusb driver.i have just got up and the player is now fully off
paul01609 20th Oct 2007 8:27 am
sorry im running windows xp
paul01609 20th Oct 2007 8:38 am
now found the driver located in the rockusb driver in the folder
Riolist 20th Oct 2007 8:45 am
Ok, you say you have a known good version of the firmware, right? So, start up the NEW updater program (the one you just installed) and load the known good firmware into it, and tell me if it loads without any errors with all four boxes filled with data.
paul01609 20th Oct 2007 8:52 am
all the boxes are filles with the flash data,in the fw toolbox is has info in there but its in grey where all the rest of it is in white
Riolist 20th Oct 2007 8:59 am
Alright, now, this is the important part. Do whatever you did before to get the computer to detect the player as 'Unknown Device' (whichever button you held down, and with the switch in the 'off' position) Once that happens, click on that notification box and you will enter the driver installation process. There are several steps you have to go through, but whatever you do, DON'T let it search for a driver or choose a driver!!! You want to guide it to that RockUSB driver in the folder I told you about before, which is inside the install folder of the updater program. Once you've loaded that driver, click on the update button in the updater program and it should work. If you don't understand any of these steps, don't guess, ask me for clarification.
