big mistake flashing onda 858le any possible help
  #41 (permalink)
Old 20th Oct 2007, 2:50 pm
Originally Posted by paul01609";p=&quot View Post
thx m8 now i just need to find out how to put movies on the frigging thing lol,says it play avi but nothing seems to work,and thank you for all your time and help
Hey your welcome, i'm glad it ended well. Movies is easy. Just download the latest avi converter software from the downloads section (tools. page two, avi converter 4 in English) set it to the resolution of your screen and the qualtiy you want and it'll convert just about anything you throw at it, and it's pretty fast.
  #42 (permalink)
Old 20th Oct 2007, 2:56 pm
guess i wont be updating it again lol,or next time i need to read stuff a bit longer
  #43 (permalink)
Old 20th Oct 2007, 8:39 pm
Yea updating is usually bad news unless it comes from the company itself. Theming can be fun though, and it's fairly safe. There's a few Rockchip firmware editing programs around (they actually just allow you to edit the pictures found in the firmware, not the OS-level stuff) so you can change the look of the player.
Big problems with hacked 16gbs Onda clone (?). Cant low level format or flashing it!! W4XiM3 General Discussion 2 28th Oct 2009 11:10 pm
FM radio reception on my Onda 858LE bishy96 Support and How To 1 16th Dec 2007 5:11 am
ONDA 858le MP4 - what converter software to use? ben2001 Video related 3 2nd Dec 2007 8:32 pm
ONDA 858le MP4 help ben2001 Support and How To 3 29th Nov 2007 12:21 pm
Wrong flashing ONDA VX858LE heat666 Dead Players 12 24th Nov 2007 8:31 pm
