Wrong flashing ONDA VX858LE
Old 20th Oct 2007, 11:54 pm
Default Wrong flashing ONDA VX858LE
Hi,
first. thank so much from your suggestion...(Riolist,knob,DaremoS,...)
i have same problem (paul01609, dnul and ...)..flash wrong firmware.
...touchscreen and buttons not working...
i try from your suggestion
"knob"
1) Switch the player OFF using the main on/off switch.
2) Hold down the menu key and keep it held down.(may be a different key for you but there are only 5 to try anyway)
3) Connect the usb to the player.
4) Wait for about 10 seconds before releasing the menu key.
5) You are now in upgrade mode!
6) Then just start ConsumerUpdate and upload a working firmware
and "Riolist" i try step by step ...my computer can see USB Mass storage device. (1.RockChip Usb mp3 usb device.. Generic volume E: 2.RockChip Usb SD USB device.. Generic volume F
but touchscreen and buttons not working too..show as pics..(i understand u "paul01609" )
website::> http://www.houseofdap.com/forum/view...st=0&sk=t&sd=a
website ONDA VX858LE::> http://www.onda.com.cn/pro/product/product.jsp?Id=11806
...FIRMWARE UPDATE FOR ONDA VX858LE and Refresh Firmware Tool version 2.8.1....
http://www.onda.cn/pro/download/bios...?ITEM_ID=11806
This is spec ONDA VX858LE chinese language website::>
http://www.onda.com.cn/pro/product/p...?Id=11806&PT=2
Pls. help me to recover my dead player
Old 21st Oct 2007, 5:04 am
Default Re: Wrong flashing ONDA VX858LE
Originally Posted by heat666";p=&quot View Post
and "Riolist" i try step by step ...[color=red]my computer can see USB Mass storage device. (1.RockChip Usb mp3 usb device.. Generic volume E: 2.RockChip Usb SD USB device.. Generic volume F
You are not in the correct mode. Those are the data partitions, you need to get into the upgrade partition, which is hidden and can only be accessed either 1) with the player 'OFF', holding a button down then plugging in to computer, or if that doesn't work 2) shorting pins on the memory chip inside the player, as Paul did. In addition, once the computer is connected to the upgrade partition you have to load the correct driver, which is in the install folder of the upgrade program on the computer, then you'll be able to flash the correct firmware. Read and re-read the other thread, all the information is there.
Old 21st Oct 2007, 5:33 am
i tired all ways to try get my pc to see the device as a rockusb with no luck and spent about 12hrs trying to sort it.in the end i opend the back and used the shorting pins trick on the chip which in total took me about 3mins inc opening,at the end of the day i had a almost dead player so i had nothing to looose but it worked
Old 21st Oct 2007, 5:48 am
ok i opend up my player again and taken some photo of the inside,just get a very thin screw driver to prize open the back of the player(you prolly will leave some marks on the plastic)then carfuly remove the battery but go steady as the battery it glued down,then leave the player tuened on and connect it to your pc with the usb,on my chip i have a large v shape looks live a pen mark at the bottom of the v and to the left of it thats where i made the connections with twizers,if you join me on msn i have a picture of the chip and area i did the connections on,i carnt say which ones i connected because i carnt remember it was more look on my behalf,msn is paul01609@hotmail.com
Old 26th Oct 2007, 6:05 am
the correct way to make your computer connect is:
short circuit the flash's 29 and 30 pin. hold it and connect the USB cable. after hearing connect sound from ur PC, release the short circuit.
Old 27th Oct 2007, 11:22 pm
hi, paul01609 how about your player(onda vx858le) .i opened up my player and i don't know how to short circuit legsROCKCHIP RK2608A from interuptor0,Riolist ,knob,DaremoS supported. my chip(ROCKCHIP RK2608A) like this
http://www.mympxplayer.org/inside-th...ight=short+pin
Old 28th Oct 2007, 12:38 am
There is more information on recovering this type of player here:-
http://www.mympxplayer.org/2-vt7807....=asc&&start=15
Please make sure you only try to flash the CORRECT firmware.
VX858 and VX858LE are 2 different players and their firmwares are NOT the same! :shock:
The VX858 uses a separate audio chip, VX858LE doesn't. :shock:
Here is a photo showing which 2 pins you need to short (29 and 30).
Hope this works for you... :idea:
Old 28th Oct 2007, 1:54 am
hi, knob
you meaning shot pin 29,30 rockchip rk2608a or sumsung 725(flash memory) .thanks you for your support.
Old 28th Oct 2007, 2:53 am
NO, Not the Rockchip try the flash that's the same shape like the one in the picture above, might say "Hynix" or "Samsung" on it or another brand on it, must have the same shape as the chip in the picture.
Old 28th Oct 2007, 3:08 am
Thank you to all for your kind support . Now i recover my ONDA VX858LE already...Here is datasheet sumsung 725 (K9LAG08U0M) for short pins 29,30 http://www.touchdev.net/wiki/Image:K9LAG08U0M_0.7.pdf .
you can do by "knob" guide at http://www.mympxplayer.org/rockchip-...=dead+rockchip
Thank you very much again.
Big problems with hacked 16gbs Onda clone (?). Cant low level format or flashing it!! W4XiM3 General Discussion 2 28th Oct 2009 11:10 pm
Skinning Onda VX858LE Dancemammal Mods and Themes 44 5th Mar 2008 8:10 am
Onda VX858LE alexknobbe Mods and Themes 3 10th Dec 2007 2:48 pm
Onda VX858LE wrong firmware flashed! Apocaliptica Dead Players 3 24th Nov 2007 8:23 pm
big mistake flashing onda 858le any possible help paul01609 Dead Players 42 20th Oct 2007 8:39 pm
