atj2051h hy27uf082g2a chip sets need filmware help
Old 8th Nov 2007, 7:25 am
Default atj2051h hy27uf082g2a chip sets need filmware help
ok well im stupid, i tryed to change my background on my mp3/mp4 player, and i got a program and thought i was backing up the f/w and my dum butt forgot to look inside to see what ver F/W it had and pow out it went thought it was a thro away and saw ya'll post on makeing it work again so i undid the cover and jumped the pins to get my pc to see it again and used a 3.5.37 filmware to get the blue screen ,now the deal is to find the right f/w the player looks like this
here ---->clik here to see what mine looks like.
and here--->same here!
ok i do have the chip set numbers atj2051h is on the small chip inside and hy27uf082g2a is on the biger chip the one i use to jump it to recovery mode,
my pc says there only 244mb on the player after i format .and one thing thats weard is i had to buy some earphones that have a 2.5mm adapter rather then the reg standard 3.5mm plugin .
now i just need to know what or where should i start?
what makes this hard is there no name brand and the one player pic says there 9.x.xx f/w and they dont seem to work and when i opened the bins in s1res.exe they dont look like the flimware that was on it,
the 3.5.37.002 thats on another pm3 player i have looks like the menu but less options in setup.
please someone point me in the right place im lost in to where to start
and one more thing how can i tell if its a full ver or a dump and why anit the full ver and the dumps in difrent places i cant tell what one are what some say there full ver and there dumps...
opps and do i have to put it back in restore mode :"jump pins" to install difrent ver like 9.0.48 and if it dont start up with menu jump pin and then try 9.0.50 ???
help me help me ATJ2051h chip thehunterx Firmware 0 13th Jun 2008 3:48 am
Looking For MP3 Player 128MB FIRMWARE : Chip ATJ2051H bathrinath Dead Players 3 11th Dec 2007 7:05 am
I need firmware HY27UF082G2A atj2085h visionmaster20 Dead Players 3 28th Oct 2007 10:55 pm
Player Sets Bitrate to 0kbps MartinS General Discussion 3 1st Feb 2007 5:05 am
Atj2051H Baskot Dead Players 0 26th Nov 2006 8:22 am
