NEED FIRMWARE!!!!
hi guys i have the FW 9.1.52 http://www.mympxplayer.org/image-asp506.html and i need the newest firmware because for some reason when i transfer amv on my mp4 it says firmware error im thinking its cause i need an update and the mp3 utilities got updated so please send it to jeffreyk8@gmail.com
Updating your firmware will most likely brick your player. Stick with the firmware that came with your player as it is made for it.
Your player might be hacked. Hacked memory results in numerous errors. Follow the instructions here:How To: Removing a Memory Hack |
Re: NEED FIRMWARE!!!!
ANYKA US B 1.1 Nad Res Z USB Device :D
BIOS kG891 MLC V0.0.12B Joy MP4 Player Download Frimware firmware bios Radio , Movie , Camera 1.3M 1,3 Mpixels , 1.3Mega pixel Games NES Software : D B-Z-M 6.0.0L9 Hardware : DVT2.1 Audio : V0.5.29bch2 soft Mb AkResData.bin kg891.bin lang_font.bin http://www.megafileupload.com/en/fil...layer-rar.html http://files-upload.com/files/630324/softmp4player.rar if your Portable Media Player have problem with software here you can download this archive press start button, and keep pressed, when is show blue screen and " Insert usb cable ..." pleas insert your usb connector cable, afther this press play button, and you will see : press Menu if you want to low format or lowformat ...or other key . pres left or right key ! DO NOT PRESS MENU !!! now your computer will recognize the device us ANYKA US B 1.1 Nad Res Z USB Device and you will have in MY COMPUTER 3 new partition removeble now create one new directory in your desktop from your computer, where to make back-up your software from this new partition, (just in cases) after you make this backup Always BACKUP the existing firmware of your player before attempting to update the firmware on your mp4 player. Updating your mp4 player with the wrong or incorrect firmware will result in a DEAD PLAYER and it not booting up at all! Always be sure that you use the correct firmware for your mp4 player only. Updating your firmware will NOT provide you with any extra features. It's really intended as a resource and 'backup' should the firmware on your mp4 player becomes corrupt. copy this files after the description: from the "partition 1" in the first of this partition from the "partition 2" in the second partition from the "partition 3" in the 3th partition. http://www.megafileupload.com/en/fil...layer-rar.html http://files-upload.com/files/630324/softmp4player.rar http://www.mediafire.com/?6x1ix0efzmz http://www.mediafire.com/?6x1ix0efzmz http://www.4shared.com/file/29824165...mp4player.html e-mail flobucuresti(at)yahoo.com |
| All times are GMT -7. The time now is 4:21 am. |
