Checkout firmware 9.1.52
Old 14th Nov 2007, 5:10 am
Default Checkout firmware 9.1.52
Necesitamos el firmware para mp4 version 9.1.52
We need the firmware to mp4 version 9.1.52
Nous avons besoin du firmware à mp4 Version 9.1.52
Χρειαζομαστε του firmware για να mp4 εκδοση 9.1.52
We moeten de firmware te MP4 - versie 9.1.52
Abbiamo bisogno del firmware a mp4 versione 9.1.52
Precisamos de firmware a mp4 versão 9.1.52
Мы должны микропрограмму в mp4 версии 9.1.52
を必要としてファームウェアを可能なmp4バージョン9.1.52
我们需要韧体的mp4版本9.1.52
我們需要韌體的mp4版本9.1.52
우리가 필요로 펌웨어를 mp4 버전 9.1.52
Si vos lo tenes lo podes subir a rapidshare.com o algun servidor similar. Tambien podes enviarlo a lasbolasdemahoma@gmail.com
Si vos tenes un mp4 con ese firmware lo podes extraer con s1clone.
If you have what it can climb rapidshare.com server or some similar or email lasbolasdemahoma@gmail.com.
If you tenes a mp5 with firmware so that we can draw with s1clone
s1clone
[web:db233eb7b9]http://firmware-v9-1-52.blogspot.com[/web:db233eb7b9]
Old 14th Nov 2007, 8:51 am
I have now tried S1Clone three times and it does not work!
I managed to purchase six MP4 Players (two identical pairs of different models).
Although S1Clone does appear to work and takes approx. five hours to create the file, it does not work when flashed to the identical players.
There are lots of 9.1.52 firmware files available but all totally different, 1.5, 1.8, 2.0 screens , portrait or landscape, different button layouts and there is even the new iPod video clone that takes 9.1.52 firmware but it has the new Apple type USB plug and the volume button is in the centre of the click wheel.
I think you should put photos of your MP4 Player and as much details such as chip, lcd, pcb numbers etc. on your web page.
Old 14th Nov 2007, 9:32 am
It is true what you say but I am looking for any version firmware 9.1.52 to make a collection so I will not give special features as this limited the amount of firmwares, and the more is better.
With regard to s1clone tries to delete or copy to the pc first, everything you have in the mp4 and then use the s1clone so you take less time and looking after the file *. fw * bin, or similar extecion, and that's the firmware.
Sorry for my english.
milimili
Old 14th Nov 2007, 9:43 am
Before I used S1Clone all the players were formatted and checked for correct size so the file was just the image.
The problem is that S1Clone creates a complete raw image and that is why it is so large and takes so long.
The only success I have had with flashing firmware is when I use the full firmware from the included disc or from the sellers web site.
I have even been successful with firmware with different numbers but only playing music and as a mass storage, but no screen.
Old 14th Nov 2007, 9:52 am
you can send me a full firmware from the included disc and the seller web page?
Old 14th Nov 2007, 10:23 am
I have too many and they are too large to email.
There is already a lot of good firmware's on this site but you need to open them up with the resource editor to at least check that they are for the same screen size and have a similar menu layout.
Have you tried http://www.uxcell.com/mp3mp4-players-c-981.html
Check their products first for model codes and then go to their download pages and select the firmware.
Do you have some details of your MP4 Player, photo's or at least a link to eBay with a similar player?
Cheers, Douglas
Old 14th Nov 2007, 10:44 am
Cheers, Douglas
do you have firmware 9.1.52, xxx.fw or xxx.bin? can send my? this can´t more 5mb large
Old 14th Nov 2007, 11:09 am
I have five 9.1.52 firmware files - 4 x .BIN files ( downloaded ) and 1 x .FW files that came with on a disc ( landscape / 2.0 LCD )
Again, can you supply details of your MP4 Player, this may help other users, that's what this forum is for.
Old 15th Nov 2007, 4:32 am
Default Re: Checkout firmware 9.1.52
My mp4 is 1,8 scream and Click the image to open in full size.
So I like all FW because can use other users. thanks.. can you email lasbolasdemahoma@gmail.com or send a PM whit Attachment?
Old 15th Nov 2007, 1:15 pm
Firmware 9.1.52 extracted with s1clone v1.2 has 40mb cause it has all the media from factory included. Belongs to a 1GB Nano Clone.
Try it!
http://rapidshare.com/files/69930004/firmware.bin
Good Luck to all of you.
