[solved] Firmware 9.5.1 ATJ2092N 2007-07-29
Old 14th Nov 2007, 11:53 am
Default [solved] Firmware 9.5.1 ATJ2092N 2007-07-29
Hi, I'm desperately looking for the firmware for this Glacier like player with the name MP4 Digital Player in it:
It's an ATJ2092N proccessor with a hy27ut088g2m memory. It came with the 1.9.5.1 firmware but I forgotten to make a dump of it. In the motherboards is written:
v4500-92v1.0 20070729
I've tryed lots of the firmwares in the forum but no one seems to work.
Thanks.
Old 14th Nov 2007, 4:45 pm
shader , there are some sets of "Glacier" firmwares in the downloads section:
http://www.mympxplayer.org/firmware-...res-df602.html
http://www.mympxplayer.org/full-firm...res-df652.html
Old 15th Nov 2007, 12:04 pm
Default Re: Firmware 1.9.5.1 for MP4 Digital Player ATJ2092N 2007-0
Hi lattesurf, thanks for your help but no luck.
Old 6th Dec 2007, 1:05 pm
I bought the same MP4 player, It is dead now. Could someone know where to download a full firmware 9.1.51 for this type MP4 player?
Old 8th Dec 2007, 4:59 pm
zhqsu , most firmwares even if they have the same version number as yours, usually would not work. This is because the manufacturers do not practice proper versions control.
The only solution is to try each and every one of the v9.xx firmwares for your screen size until you get a working one.
Old 9th Dec 2007, 9:35 am
Wow! Finally I've found a working firmware for this!
Thanks to NautyWood on this thread:
http://www.mympxplayer.org/viewtopic.php?p=42118#42118
Ive uploaded the file here:
http://www.exclat.com/files/MP4_Digital_Player_9.1.51_firmware_s1clone.zip
It works!!!
Old 9th Dec 2007, 1:53 pm
shader , good on ya. It would be good to keep the backup copy safely, just in case you need it in future.
Old 25th Jun 2010, 6:03 am
Default Driver
Hello , i need the driver for this MP4 player .
I don't have the disc anymore , and my computer does not detect the player.
On the screen is only a hourglass Click the image to open in full size..
it stays forever .
What can i do ??
Looking for ATJ2092N board ID: HX 25056S xonic Dead Players 0 3rd Feb 2010 1:02 am
Looking for firmware ATJ2092N plate v4500-92v1.0 Mouss Firmware 5 11th Jul 2008 8:45 pm
Need Firmware for ATJ2092N LH-036AK Chisamba Dead Players 2 26th Feb 2008 10:59 pm
8GB GLACIER v4500-92v1.0 20070729 ATJ2092N RaggedEdge Firmware 0 21st Feb 2008 9:17 am
8GB GLACIER v4500-92v1.0 20070729 ATJ2092N HELP!!!! RaggedEdge Dead Players 0 21st Feb 2008 9:12 am
