how long to upgrade the firmware process usualy?
Old 16th Nov 2007, 7:21 pm
Default how long to upgrade the firmware process usualy?
cause when i upgrade tre progres stop in 5 bar?
thanks
Old 16th Nov 2007, 7:56 pm
dunksall , flashing usually takes a few seconds. If it stops, then likely it has hung. Either exit the software and re-flash again, or else uninstall the MP3 Utilities and install another version. Some versions are known to hang with some players for unknown reasons.
Old 16th Nov 2007, 8:57 pm
ok thanks for the answer i hope it work with my player
Old 17th Nov 2007, 12:31 am
upgrade half-way hang means upgrade tool version not correct or flash memory poor soldering.
How long does the firmware upgrade process take ? MakaveliThaDon Support and How To 0 21st Aug 2008 5:12 am
How long does the firmware upgrade process take ? MakaveliThaDon Support and How To 0 21st Aug 2008 5:10 am
Firmware copy process gorib65 Dead Players 1 15th Apr 2008 4:06 am
How long before firmware gets uploaded? fhussain General Discussion 3 22nd Feb 2007 3:51 am
How long usualy MP3 Ugrpade tool upgrading firmware ? ashtry Dead Players 5 13th Dec 2006 12:44 pm
