Looking for firmware act_V9.1.51 2007/05/14 CM 50012
hi quelqu'un peut me donne le firmwar de cet clone ipod nano 1G :oops:
k138v1k1 CM 50012 2007/05/14 act_V9.1.51 merci d'avance |
halim , your player would be using the v9.xx series firmwares here http://www.mympxplayer.org/actions-9...ware-dc37.html
As there is no way to tell which firmware would work properly with your player, you'll need to try all those for your screen size until you get a working one. Good luck. |
jai bien cherché mais aucun resultat
plz tu peut me donner le firmewar firmware act_V9.1.51 2007/05/14 CM 50012 |
1.8 PY-1328[rfd]
halim , i have already said that there is No Way to identify which firmware would work with your player fully. You need to try all of them.
ok je vais essayer de tester tous les firmwar
mon amie pour plus info sur mon clone ipod voir ce lien plz
http://cgi.ebay.com/ws/eBayISAPI.dll...m=110195169499 |
| All times are GMT -7. The time now is 4:21 am. |
