Dead ONDA vx858 copy
Old 22nd Nov 2007, 5:33 am
Default Re: Dead ONDA vx858 copy
well yes, everytime i install a firmware it shows the screen with music video games fm.. and so on, but the touchscreen is blocked... so i guess until an rockchip firmware extractor appears or i find the right firmware, the player is dead..
Old 22nd Nov 2007, 6:23 am
Answer this precisely please... each time you load a firmware it shows corresponding menu... for instance when you installed VX868 appears VX868 menu?
Did it show the initial sequence of loading the software?
I wonder if the connection between the screen and the processor is ok... I mean electrically
Old 22nd Nov 2007, 6:29 am
Maybe you can try resetting the Bios Flash with the NAND tool... download it from here NAND tool
Old 22nd Nov 2007, 10:39 am
when i load a firmware and put it into the mp4, i open it, it says init system or something like that and then the menu appears, i think that everytime the menu was the same.. it looked like the original firmware that i had but the letters are in chinesse. i will try resetting the bios flash and post here after i do it.
Old 22nd Nov 2007, 10:58 am
i opened the nand tool, i can't even see the full window.. :x
  #16 (permalink)
Old 22nd Nov 2007, 11:45 am
change screen resolution just to see the program... this program could solve your problem
  #17 (permalink)
Old 22nd Nov 2007, 3:57 pm
oh damn, i think i have another problem... the computer can't recodnise the mp4 player as usb rockchip.. i can't update firmware or anything like that, it says usb device not found... when i resuscitate the mp4 player the computer says new hardware found, new hardware installed and then the port screen appears it says unknown device.. and also near the clock a window pops up and says device has malfunctionead... i think i fuc;ed up the mp4 :shock:
  #18 (permalink)
Old 22nd Nov 2007, 4:57 pm
Your player is not fucked up!
That's normal... don't get depressed
Read the following first Rockchip recovery guide
  #19 (permalink)
Old 24th Nov 2007, 8:18 pm
I used the NAND Flash tool to clear out both of my NAND Flash RAM Chips, and updated with every single Firmware that ONDA has to offer, and my touch screen is still dead, however, it does boot up normally, and showed System Init... Screen everytime I reflashed the firmware....
  #20 (permalink)
Old 25th Nov 2007, 2:23 am
hello,
first pls excuse my English, im not so good at writing.
I got one ONDA vx858 (last month) and i upgraded yesterday to v0017. for my luck i used the v1 version DaremoS posted here, later i discovered that there are 2 versions. So i want to ask what are the differences and how can i identify my version.
oldno8 pls pm me.
FM on Onda VX858 copy mayster Support and How To 0 13th Dec 2008 11:06 am
dead Onda VX858/VX858LE player... L337 Dead Players 4 25th Jun 2008 4:13 am
Onda vx858 2GB pyroevil Support and How To 0 13th Jun 2008 8:42 am
PROBLEM dead mp4 player Onda VX858 2GB fortissimo91 Dead Players 0 6th Dec 2007 9:54 am
Onda VX858 fortissimo91 General Discussion 1 14th Oct 2007 8:20 am
