Dead ONDA vx858 copy
Old 21st Nov 2007, 8:08 am
Default Dead ONDA vx858 copy
Hi, i have an onda vx858 copy (it looks the same, it has(had) the same menu).. on the front of the mp4 player is written I'deko.
ok, i tryed to update the firmware with the program called firmware update, i opened a c260 rfw firmware update and bloked the player, it couldn't be closed anymore and the touchscreen stoped to respond. I followed the dead mp4 player guide and it recodnised again my mp4player so i could update the firmware again, i installed the vista rfw and now when i open the player it's the vista menu but the touchscreen doesn't responds. i think i need the full firmware.. i was thinking to buy the same mp4 player again and extract the firmware and put it on the bloked mp4player... i don;t know.. it has a rockchip rk2608a b75941 0739. if anyone has the correct firmware or one that can work... :shock:
Old 21st Nov 2007, 8:34 am
Default Re: Dead ONDA vx858 copy
GOSH!!!!... you did use a Teclast C260 firmware in an Onda VX858 player!!!???
Sorry to say you are doing everything wrong: anyway, do the same trick again but this time install a VX858LE firmware if it this is the type of player.
Rockchip player CAN'T be extracted its firmware. you just need the one supplied by the provider. Go to the provider and ask him the firmware.
Old 21st Nov 2007, 8:54 am
yup, i wanted to have playfx and organized music :cry:
the guy from who i buyed the mp4 player doesn't have the firmware
where can I find a vx858le firmware and what's the difference between a vx858le and vx858 ? what's that LE ?
Old 21st Nov 2007, 10:50 am
here is an explanation VX858 vx VX858LE... the problem is that VX858 using VX858LE firmware get locked and vice versa... show menu but buttons are locked... to recover them it's needed to open the case and use short-circuit method.
Here is Onda ftp Onda FTP
Old 21st Nov 2007, 11:36 am
damn, i think it's not an LE. here is the description of the mp4 from the seller:
2.8 inch high clear QVGA screen
Support 2GB storage capacity and SD Card
Built-in WOLFSON WM8750 independent audio chip, more perfect sound USB 2.0 high speed
8 EQ model: Jazz,Classic,Pop,Rock,Nature,3D,Bass,user-defined
Support mp3,WMA,audio and support MEP-4 AVI movie
Support MIC record, FM record
Built-in FM radio with 20 channels
Graphics operation interface, songs listed files
7 play models
Multitask
Support multiple language
Support e-book and book mark
Support synchronous lyric display and support LRC lyric file
Support JEG photo browsing
Automatism power off
Firmware upgrade
Built-in 1000 MHA Li battary
also, i opened the mp4 and it has 3.. things :
etrontech em636185ts-7 1081404rcs965.1h
samsung 731 k9lag0800m pcbo fefl100bbc
so i don't know if it really has a Wolfson WM8750..
here is a picture, it's not very clear but.. http://img519.imageshack.us/my.php?i...oto0165nm9.jpg
Old 21st Nov 2007, 12:03 pm
7 play models
Multitask
Firmware upgrade
you mention 3 chips: Rockchip which is the processor. Etron Ttech which is the BIOS and Samsung 731 which is the Flash memory. Wolfson is a small chip black with letters WM on top, it could the the black square on top at the left. should look like this Click the image to open in full size.. with a different number. On the right a little below of this is another black square which could be FM radio.
Anyway you have nothing to lose by trying a VX858LE. With the player already opened you can short-circuit Samsung 731 chip to recover your player.
Old 21st Nov 2007, 1:00 pm
i tryed :
Vx858_V2_V00.02.0017.rar 1588 KB 9/26/2007 4:38:00 PM
VX858LE_V1.0.40.rar 1573 KB 10/23/2007 11:19:00 AM
VX878_v2_v2.0.5.rar 1628 KB 10/20/2007 10:20:00 AM
i open the mp4 and the touchscreen is freezed.. when i connect the mp4 with the usb , on the screen it's a usb sign or something like that, i think that when i had the original firmware the usb screen was different
Old 21st Nov 2007, 3:06 pm
i tryed :
Ok... at this stage you just need to try other firmwares... try VX868 which have the same screen than VX858
I've seen a photo of your player I'deko LK 028 and It's unbelievable that firmware of Onda VX858 doesn't work on it... anyway... try Onda VX868 in the same FTP I sent you.
Old 22nd Nov 2007, 4:38 am
:x i tried almost all the firmware from the site, they don;t work
i don;t know what else to do, i guess the player is dead :cry:
Old 22nd Nov 2007, 4:47 am
The player is not dead as it allows you to update firmware... you reach menu screen but touch panel don't work...
each time you put a new firmware menu screen changes, showing the new firmware... isn't so?
FM on Onda VX858 copy mayster Support and How To 0 13th Dec 2008 11:06 am
dead Onda VX858/VX858LE player... L337 Dead Players 4 25th Jun 2008 4:13 am
Onda vx858 2GB pyroevil Support and How To 0 13th Jun 2008 8:42 am
PROBLEM dead mp4 player Onda VX858 2GB fortissimo91 Dead Players 0 6th Dec 2007 9:54 am
Onda VX858 fortissimo91 General Discussion 1 14th Oct 2007 8:20 am
