"AdfuUpdate" - provided does not contain the drive
Old 22nd Nov 2007, 6:44 pm
CANNOT INSTALL THIS HARDWARE
There was a problem installing this hardware
USB 2.0 (FS) ADFU Device
An error occurred during the installation of the device
The required section was not found in the INF.
Old 22nd Nov 2007, 7:05 pm
jakebache , i think the problem lies in that your computer registry does not have the ADFU string, which causes the failed installation.
Try going to your Windows Registry to add the ADFU into it.
Click Start >> Run
Type regedit
Click Ok
Now in the Registry Editor, browse to the following directory:
HKEY_LOCAL_MACHINE >> SYSTEM >> CurrentControlSet >> Control >> Class
Right click on Class and select New >> Key
You will notice that a new folder would be created with default filename like New Key #1
Change the "New Key #1" to {1181f4a0-f284-11d2-9068-00609797ea5a}
Be sure to include the 2 brackets as above.
Once done, you can close Registry Editor, and try updating the driver again using either of both files i've uploaded:
http://www.savefile.com/files/1207727
http://www.savefile.com/files/1205168
Old 22nd Nov 2007, 7:11 pm
Click Start >> Run
Type regedit
Click Ok
Just did it,
Still getting same error messages
Need "private key" and "devcert template" adminn Support and How To 1 31st May 2010 5:07 am
INSERT ANY DISK IN DRIVE J: "in USB MESSG HELP !! rahulmig Dead Players 2 18th Feb 2007 3:03 am
"Blown-z" now trading as "excesories" tadad1 Bad sellers/Blacklist 2 15th Feb 2007 5:09 pm
[solved] USB 2.0 "Full" and "Hi" speed i Zepheris Miscellaneous 4 12th May 2006 11:18 am
