"AdfuUpdate" - provided does not contain the drive
Old 21st Nov 2007, 3:47 pm
Default "AdfuUpdate" - provided does not contain the drive
Hey Guys,
I brought a 4GB fake iPod from China.
Tried to upgrade the firmware and now its only displaying a blue screen.
I followed the tutorial on "Dead Players" but I couldn't finish it.
I got to the point where I had to install new hardware, as the player was now being recognised, but it says to click "have disk" then to browse for a file called "AdfuUpdate"
But my windows folder looks nothing like that on the tutorial, and i cannot complete the process because the disk provided does not contain the driver.
Anything would be great!
Old 21st Nov 2007, 11:59 pm
jakebache , go to Control Panel, and click on System.
In it, select the Hardware tab, then click on Device Manager.
Now you should see a list of hardware items connected to your computer. Look for the player, it should be highlighted with a yellow exclamation mark.
Right click on it and select Properties.
A new box should open. Now select the Details tab and in the drop down box, chose Device Instance Id.
What does the box below it display after you selected it?
Old 22nd Nov 2007, 2:11 am
Default Re: "AdfuUpdate" - provided does not contain the d
USB\VID_10D6&PID_FF66\5&18793D26&0&2
Old 22nd Nov 2007, 5:34 am
jakebache , try the ADFU files here http://www.savefile.com/files/1207727
Old 22nd Nov 2007, 12:51 pm
ADFU driver don't work on WindowsXP x64, Windows 2003 x64.
Old 22nd Nov 2007, 12:59 pm
Yeah, It went through to the next bit, but then came up with errors. and couldnt complete. Still no progress
Old 22nd Nov 2007, 5:43 pm
jakebache , what specific errors did windows show?
Old 22nd Nov 2007, 6:24 pm
CANNOT INSTALL THIS HARDWARE
There was a problem installing this hardware:
%USB\VID_10D6&PID_ff66.DeviceDesc%
An error occured during the installation of the device
The required section was not found in the INF.
Old 22nd Nov 2007, 6:33 pm
jakebache , what OS are you currently using?
Try this ADFU file instead http://www.savefile.com/files/1205168
Old 22nd Nov 2007, 6:38 pm
I am using XP, with a vista skin, shouldn't change anything though.
Need "private key" and "devcert template" adminn Support and How To 1 31st May 2010 5:07 am
INSERT ANY DISK IN DRIVE J: "in USB MESSG HELP !! rahulmig Dead Players 2 18th Feb 2007 3:03 am
"Blown-z" now trading as "excesories" tadad1 Bad sellers/Blacklist 2 15th Feb 2007 5:09 pm
[solved] USB 2.0 "Full" and "Hi" speed i Zepheris Miscellaneous 4 12th May 2006 11:18 am
