Sigmatel recovery guide (Updated)
  #31 (permalink)
Old 27th May 2008, 7:36 am
hi ^^
plz i need firm to mu mp3 player
Packard Bell AudioDream 256MB
chip:
Sigmatel
STMP3505
L100-TA4
T01296
0453
  #32 (permalink)
Old 28th May 2008, 10:55 am
I have a STMP3600 based MP3 player.. which firmware I use to it?
  #33 (permalink)
Old 29th May 2008, 6:18 pm
why no one is here ?
  #34 (permalink)
Old 9th Jun 2008, 10:38 am
Default Re: Dead 4ever?
Originally Posted by sustmi";p=&quot View Post
Summary of the problem:
- after update to wrong firmware the capacity went from 2GB to 1GB.
- only 1GB firmware booted well
- with 1GB firmware only one of two NAND chips was accessible
whole problem description:
http://www.mympxplayer.org/image-vp49144.html#49144
SOLUTION:
The problem was that the second NAND flash chip contained wrong data.
But I found the way how to erase both chips and load the firmware to the clean memory.
The chip can be erased by special SCSI command.
1.) Get the SCSI Utility from http://logix4u.net/.
2.) Connect the player to PC and initiate the Recovery Mode with updater.sb that works (in my case it was 1GB firmware v006.003.260)
3.) Run the SCSI Utility and press F5 to refresh list of connected devices
4.) Right-click on the player in the list and choose "Execute Custom CDB"
5.) Then fill the table with these values:
Code:
BYTE 0: c0
BYTE 1: 7
BYTE 2: 0
BYTE 3: 0
BYTE 4: 0
BYTE 5: 0
Other cells leave blank, so the CDB Size will be 6.
(Values are in the hexadecimal form.)
6.) Then press Execute, accept the warning and wait a moment (10 sec.).
Now the first chip is clean.
The problem is that when you have 2 chips.
You must do a "reconnection" in order to access the second chip. But don't worry, it isn't so hard as it sounds. :wink:
1.) You must disassemble the player
2.) Check the NAND chip (there is only one physical flash chip, but it consists of 2 separate logical chips)
3.) Google the datasheet for you memory chip.
4.) Now you must short-cut (make a connection) the CE1 (Chip Enable 1) pin to Vcc=3.3V (if it is the specific voltage for 'logical one') to disable the first chip.
5.) Short-cut the CE2 (Chip Enable 2) pin to Vss=0V (GND) to enable the second chip.
6.) Do the erase process with the SCSI Utility again, now with the second chip.
7.) Remove the wires (the shortage).
Now you can boot (initiate Recovery Mode) with the 2GB uploader.sb and flash the 2GB firmware (select the Format Data Area in the flasher utility).
This is how I did it. Now I have whole 2GB of capacity back.
Maybe it should be enough to erase only the first chip. I have erased both and it works.
[hr:d06de38292]
Example NAND flash datasheet:
http://www.datalabs.ru/files/HY27UH08AG(5_D)(Rev0.6).pdf
Complete list of SCSI commands:
Code:
byte 0:
SCSI_OPCODE_SIGMATEL_READ_COMMAND  0xc0
SCSI_OPCODE_SIGMATEL_WRITE_COMMAND 0xc1
byte 1:
GET_PROTOCOL_VERSION        0x00
GET_STATUS                  0x01
GET_LOGICAL_MEDIA_INFO      0x02
GET_LOGICAL_MEDIA_NUM       0x03
GET_ALLOCATION_TABLE        0x05
ALLOCATE_MEDIA              0x06
ERASE_LOGICAL_MEDIA         0x07
GET_LOGICAL_DRIVE_INFO      0x12
READ_LOGICAL_DRIVE_SECTOR   0x13
SET_LOGICAL_DRIVE_INFO      0x20
WRITE_LOGICAL_DRIVE_SECTOR  0x23
ERASE_LOGICAL_DRIVE         0x2f
GET_CHIP_ID                 0x30
CHIP_RESET                  0x31
If you have any questions, please ask. If you really want I can take some photos of the process.
  #35 (permalink)
Old 9th Jun 2008, 8:47 pm
Default Flashing a firmware SigmaTel 3502
Type : USB Portable mp3/wma Player
Capacity : 128MB+
Chip: SigmaTel 3500, 3502 6
Brand: Fujitel, Recco, Startek, Titan, Master-g, Hitech, etc
MainBoard: MP807C MAIN V1.1 or similar
http://www.youtube.com/watch?v=19-K6ixOpzs
--- Marko / uruS ---
mmarquss@hotmail.com
  #36 (permalink)
Old 20th Jun 2008, 7:30 am
Hello.
I have a SigmaTel MSCN Lavod Mp4 player
Its is 1 cm thin. black, has a 4/3 screen, a round pad with really odd simbols.
The problem is that the memory (2GB) can not be found anymore. not by the player itself nor by the PC.
These firmware tricks are cool and all. but how can you apply them when you can't go into the directories needed?
  #37 (permalink)
Old 24th Jun 2008, 4:08 pm
Default Problem with my Sigmatel Player
i have a problem and i dont know why happens, everytime i try to play media files in my sigmatel player, it restarts, files does not open, player restarts instead, i would to know why is that, because i tried to flash it, but the problem still. Here is a picture of my player. any kind of help will be appreciated.
  #38 (permalink)
Old 2nd Jul 2008, 10:16 am
Default Re: Sigmatel recovery guide (Updated)
Thanks for the guide...
I have a mp4 watch 2gb like this...
MP4 Watch Link
I desperately need the firmware for this watch, as mine is dead, it recognizes as flash disk and when I put it in recovery mode it shows STMP3500 (I believe this is the chip in this watch)
If anyone has this watch can you please extract the firmware and send it to me?
  #39 (permalink)
Old 16th Jul 2008, 10:58 am
Originally Posted by Th3_uN1Qu3";p=&quot View Post
STMP3504? If it has a 1.5 inch screen (square), try my firmware: http://www.mympxplayer.org/sigmatel-...500-df719.html
work with my 3504, but I not have menu, only white screen
  #40 (permalink)
Old 2nd Aug 2008, 12:15 pm
working perfectly, big thanks
Guide for Inovix IMP-64 FM recovery. skorzo Dead Players 0 27th Apr 2008 5:13 pm
Recovery Guide not working jplt44 Dead Players 1 2nd Dec 2007 5:11 pm
Sigmatel Dead Recovery Guide! NguyenPhuc Dead Players 2 25th Sep 2007 1:29 pm
Stuck following recovery guide mypreludeisred Dead Players 7 25th Jun 2006 5:08 pm
