Sigmatel recovery guide (Updated)
  #41 (permalink)
Old 21st Aug 2008, 8:24 am
Default Re: Sigmatel recovery guide (Updated)
Hey
I got this Lavod LFA 232
Sigmatel Chipset 3502
Hynix HY27UF082G2M
would like to make it possible to use mp3 player functions again.
Right now im stuck with rediculious usb memory stick function only.
It got stuck when using mp3 filetransfer on Windows Vista.
Tried files here allready I need the firmware or another working one! of this player again.
If you have one working let me know...
thnx.
  #42 (permalink)
Old 31st Aug 2008, 5:30 am
Hi Th3_uN1Qu3!
I have a Tangent Jukebox 256MB MP3 Player, LIKE THIS.
Based on Sigmatel STMP 3502 L100E-CA6 chip with board nr. 500SF V1.9
I am not able to switch it on, but when i connect it to USB port, Win finds it as Sigmatel MSCN USB Device. On the players display appears the FW version: 2.600.100
It appears also in My Computer as Removable Disk, but i'm unable to access it, gives some I/O error.
Could You please guide me what to do, and provide some firmware.
Thank You, regards.
  #43 (permalink)
Old 1st Sep 2008, 2:48 am
I have found a Fw with version 2.600.100
I did the upgrade, windows recognized as mass storage device, but now nothing appears on LCD, nor I cant switch it on.
I found another similar fw version 2. 611.101, but after update my player almost died completely. I was not able to put in recovery mode anymore, no matter how long i kept pressed the play button, nothing.
I was absolutely sure, that it was completely dead. In my desperation i've tried everithing, and with a huge luck, dont know how tho, i've started the FW download tool, and while it was searching for a device, i made the recovery procedure, and it came back alive again. I uploaded again the 2.600.100 fw, and works as a mass storage device.
I still need some help please, if somebody has a similar player, or knows some link.
Which of the files are for the play mode? Coz i dont want to mess anymore with the other ones.
Thanx!
  #44 (permalink)
Old 2nd Sep 2008, 10:06 am
Even though the firmware is modular, i could never get files from different firmware packages to work together.
If you have tried all firmware posted above or in the site's download section and none works, i'm afraid you're out of luck.
I've had a Meizu M6SL for almost an year and love it. I've given my Sigmatel player to my mom, and she only uses it as a voice recorder. It's been a while since i last played with it, and i remember spending a lot of time searching while i was messing around - firmware for those players is very hard to find, and in the end it's not really worth it.
I'm sorry i can't help you more.
  #45 (permalink)
Old 9th Sep 2008, 4:17 pm
Hello Th3_uN1Qu3,
I have a Logik oiii 2Gb Mp4 player recognized as sigmatel 3660. Using firmware extractor i have extracted 4 files from a working player.
I've tried all your programs(stupdaterapp.exe) but the only one that worked was maxfield g-flash. It recognize the mp4 in recovery mode, but it needs 6 files and I have only 4. Can you help me.
best regards
  #46 (permalink)
Old 17th Sep 2008, 6:14 am
Problem solved!
You can download the working fw from HERE!
  #47 (permalink)
Old 12th Oct 2008, 2:26 pm
Thank's a lot =) I have a MP-FUB35 2Gb mp3 player. Suddenly it said somethin' like "please, make backup of data and format me". When i connected it into PC it appears as SigmaTel USB mass storage, but didn't open, says that it has I/O error. F@cked a lot with it with many firmware updater applications and FW itself. When tried "For newer firmware (that contains hostlink.sb):" method it became alive =) Thans very much indeed =)
  #48 (permalink)
Old 15th Oct 2008, 2:30 pm
I have a sigmatel mp3 player ( Giga Rok )
Problem : no power on,black screen
i need firmware please
sigmatel 3502
1 GB
memory : hynix
  #49 (permalink)
Old 21st Oct 2008, 3:33 pm
I have MATSUI MAT 110 MR, sigmatel STMP3500/ASBR3304. When I try to flash firmware using stupdaterapp.exe it stops and informs - UPDATE VERIFICATON FAILED.
<img>
  #50 (permalink)
Old 9th Nov 2008, 8:42 am
Try this firmware, it should work for Matsui 110 MR.
http://rs211.rapidshare.com/files/47...R_firmware.zip
Guide for Inovix IMP-64 FM recovery. skorzo Dead Players 0 27th Apr 2008 5:13 pm
Recovery Guide not working jplt44 Dead Players 1 2nd Dec 2007 5:11 pm
Sigmatel Dead Recovery Guide! NguyenPhuc Dead Players 2 25th Sep 2007 1:29 pm
Stuck following recovery guide mypreludeisred Dead Players 7 25th Jun 2006 5:08 pm
