sony mp4 256mb dead lf: firmware
i'm looking for firmware for this mp4 player.
http://i13.tinypic.com/6y2jard.jpg it has 6 buttons. please help. thanks. |
jrguy8 , you'll need to open the player to identify the processor's serial number (eg ATJ2085, ATJ2097, etc). Also, do you still remember your previous working firmware version?
i don't remember the original firmware version. it uses ath2085. it support amv.
jrguy8 , the ATJ2085 uses the v3.5.xx firmwares here
v3.5.35 http://www.mympxplayer.org/actions-3535-dc15.html v3.5.37 http://www.mympxplayer.org/actions-3537-dc16.html As there is no way to tell which firmware would work with your player properly, you'll need to try all those for your screen size until you get a working one. There are many v3.5.xx firmwares, so good luck. |
thanks. i'll try those.
| All times are GMT -7. The time now is 7:42 pm. |
