Aww Still not workin plz help i have upgraded my firmware ..
Old 30th Nov 2007, 11:11 am
Default Aww Still not workin plz help i have upgraded my firmware ..
ehmm hello im new here
few hours ago i tried to upgrade my mp4 player idescribition
Made by Kingzon
1 gb without FM
series : m4- or m5- sj
i read the guide when the player is dead what to do i have done it but i tried to ugprade it and there was nothing i mean aww this pic
http://funkyimg.com/viewer.php?img=65239pla_plaJPG.jpg
i cant klick on this button x_________x to upgrade what to do?
can someone control my pc with a program and make it ?
plz add me:
icq: 190552985
msn: tschida@hotmail.de
Old 30th Nov 2007, 6:10 pm
shadowmasterz , you'll need to click on "Select new firmware file" first to chose the firmware, then you would be able to click on the "Begin upgrading" button.
Old 1st Dec 2007, 3:36 am
Default Re: Aww Still not workin plz help i have upgraded my firmwar
ehmm yeah i know i selected the firmware file but nothing >_>
Old 1st Dec 2007, 3:37 am
//sry doublepost
Old 1st Dec 2007, 4:20 am
shadowmasterz , what file format are the firmware files that you loaded? They should be either .fw or .bin extensions.
Old 1st Dec 2007, 4:25 am
how do u mean? they are .fw or .bin both i have got
o you meant that they shouldnt be this format aww where can i find others?
Old 1st Dec 2007, 4:47 am
shadowmasterz , the firmware files should be in either .fw or .bin extensions.
Open your player and check for the processor serial number (eg ATJ2085, ATJ2097, Rockchip, etc).
Old 1st Dec 2007, 5:06 am
ok i must look for it
Old 1st Dec 2007, 7:00 am
here and some codes tha you cant read are typed here
for the chip over the other chip XD:
AK1025
7D016AA 045 or 7D01GAA 045
the chip under the chip XD:
Samsung 722
K968G0V0M
PCB0
CSDU3511
Battery or something like that what is blue XD:
KE MEI DI
Model No: 042030
Capaticy: 180 mAh
3,7 Volt
6BIT18287
2000
Old 1st Dec 2007, 7:39 pm
shadowmasterz , for the AK1025, you should be using the v9.xx firmwares. However, it seems that there are not many v9.xx firmwares based on the AK chipset. However, do try all of them here http://www.mympxplayer.org/actions-9...ware-dc37.html
RK2608 with upgraded firmware gvdgvdgvd Mods and Themes 13 16th Apr 2012 8:02 am
Upgraded firmware now doesn't work mark2010mark Dead Players 17 19th Mar 2008 8:08 am
What Firmware Is This & Can It Be Upgraded ? mug2k Support and How To 1 8th Dec 2007 5:35 pm
Dead MP3. Help!!! Upgraded With Wrong Firmware? bobrules Dead Players 9 5th Feb 2007 5:35 am
New Player w/ Upgraded Firmware w/ File Browsing!! bsaylors General Discussion 15 24th Jul 2006 12:02 pm
