-   -   need some help with 1,8" mp4 player ver 9.1.52 (http://mympx.org/forum/dead-players/39805-need-some-help-1-8-mp4-player-ver-9-1-52-a.html)
sdfr 30th Nov 2007 11:44 am
Hello everybody,
Your site is very usefull, thanks for doing this.
First, i have bought 2 of these unit ( picture : http://www.mympxplayer.org/image-asp356.html ) in 2 gb version.
The firmware on is 9.1.52.
My first unit is dead by the fault of my antivirus Avast, avast say there is a virus when i plugged up the player in usb, so i do repair action and after that player still working but the usb is not recognized.
First I made a firmware copy of my working unit with s1clone soft.
So i start to made actions on dead player tutorial , trying to put player in ADFU mode, i finally do it but after adfu recognized by my computer player turned off by himself.
When i light up again, he only show a blue screen with sand clock, i try to put it again in adfu mode but with no success.
Do you have any ideas to help me?
Is my player dead ?
Also if someone look for firmware for this model I would be happy to share it with you.
full detail :
MP3 PLAYER
LKC_9101_V31
2007-08-28
9.1.52
2005-01-09
Thanks for answer.
sdfr 30th Nov 2007 12:26 pm
Re: need some help with 1,8" mp4 player ver 9.1.52
Just in addition, i just try to put him again in adfu and It's work but he's deconnecting after 3 seconds no time to put firmware on it :(
lattesurf 30th Nov 2007 6:07 pm
sdfr , the pin shorting to force the player into ADFU state is a trial and error method. You'll need to keep trying.
interuptor0 30th Nov 2007 8:52 pm
sdfr, did u remove battery while doing short circuit recovery? if not, u maybe kill the flash memory or controller.
sdfr 1st Dec 2007 3:53 am
Oooops no i didn't put off the battery, when i do court circuit there is a little lightening between 2 pins since the screen refuse to switch on, he seems to be really dead.
But battery is soldered on motherboard.
Thansk for informations, i will retry a last time but he really seems to be dead.
I post some pictures of my device if it can help someone, and remeber i have the clean firmware of these device in s1clone soft format, if anybody interested let me know.
Keep up the good work with your site.
Habbah 14th Sep 2008 6:51 am
i have the same mp4 as you cept mine is 4gb. i also have firmware 9.1.52
