DEAD - STUCK AT "load" sign -->HELP Me!
Old 30th Nov 2007, 12:57 pm
Default DEAD - STUCK AT "load" sign -->HELP Me!
Hi!
8gb / 2.0" / FM / ATJ2093 /Dead Mp4!
Images:
http://img48.imageshack.us/img48/955...2r12111ob9.jpg
http://img140.imageshack.us/img140/2...12gf32fxs1.jpg
MP4 Only shows "LOAD" sign, but it NEVER loads... :cry:
PC recognizes it as USB...I do the ADFU thing...but WinXp dont open an icon to explore MP4...AND I CAN NOT FLASH IT.....
I need some HELP! ANYONE? Tnx!
Old 30th Nov 2007, 6:06 pm
master_samo , when you start the MP3 Utilities Upgrade Tool software, does the program say anything?
Also, your player might not be a real 8GB. if you can try to retrieve all the numbers on the Samsung flash chip, you'll be able to identify the actual size of it. The Samsung 713 as i recall is a 2GB chip.
Old 30th Nov 2007, 9:33 pm
it is a 8GB flash chip. try re-solder the flash's pins or LCD's pin if u have the skill.and dun forget to take of battery b4 u doing soldering job.
Old 1st Dec 2007, 12:52 am
Default Re: DEAD - STUCK AT "load" sign -->HELP Me!
Hi!
When I Try i get this...
http://img122.imageshack.us/img122/8...sdsad21ex4.jpg
Pins are soldered OK, Chip ain't fake.....WHAT NOW???
Tnx
Old 1st Dec 2007, 2:28 am
Now i only get WHITE SCREEN, with clicking sound in the speaker...and stays in white screen....WHAT SHOULD I DO???
C-ya!
Old 1st Dec 2007, 2:43 am
If your player is detected by Windows as an ADFU Device it will not show in Explorer but the Mp3 Update Tool should be able to find it.
Old 1st Dec 2007, 2:54 am
Yea....But now it just shows WHITE SCREEN, doesnt get picked as an ADFU Device...nothin...just cliking noise when i plug it in USB and white screen....Is is complitly DEAD or WHAT ???
Tnx!
Old 1st Dec 2007, 3:49 am
aww is the same at me it did not show my mp4 at the explorer and at the upgrade tool too where can i find it?
Old 1st Dec 2007, 4:33 am
Windows Dont recognize it anymore....
Old 1st Dec 2007, 4:40 am
no i mean my mp4 is just shown at the hardware profiles
My MP4 player stuck on "loading" blue screen kichnaz Dead Players 2 28th Jan 2011 1:33 am
Need help with my LG FM37 - stuck in "rebuilding library" screen armin310 Dead Players 0 25th Sep 2009 4:51 pm
Daewoo DMG-P51 (1Gb) Stuck at "loading" screen Adverso Dead Players 11 14th Nov 2008 10:29 am
Stuck at that "usb disk" screen and NOT recognize crasymama Dead Players 0 29th Dec 2007 8:09 pm
Load music on my Glacier but saids "empty disk" astrosarehott Support and How To 7 17th Jan 2007 12:27 am
