help!!! DEAD HACHA PA20.
Old 7th Dec 2007, 12:26 am
Default help!!! DEAD HACHA PA20.
so my hacha pa20 stopped working on me out of no where. the player first became undetectable , showing as "unrecognized usb" on my windows. eventually, the player woudlnt turn on anymore. also, the player sound quality was HORRIBLE b4 it died out.
im new to this forum and i saw the recovery guide. thing is, i have NO idea on how to open the pa20. any suggestions on what i should do?
Old 18th Dec 2007, 6:20 am
8) upgrade firmware !!! I'll upload soon fw with program and how to... :roll:
Old 18th Dec 2007, 7:54 am
do you use windows vista or xp?
if you use vista, this was a problem for my PA20 as well.
as for xp, there are drivers you can install that helps with the detection, however, i have found it is hit or miss if xp will detect it. i would say 25% of the time it would detect properly.
as for fixing your player.....
i am afraid your player is bricked at this time. you cant upgrade the firmware unless the player is on. if you cant turn it on, you cant upgrade the firmware.
its very possible that something was wrong with the players electronics.
i suggest contacting the seller and see if there is anything that can be done in order to resolve this situations, ie. a replacement or refund.
i havent noticed to many hacha owners on this site so a good source of of hacha info is http://www.mp4nation.net/forum/
you might be able to short a circuit to turn it back on, but i dont know.
Old 18th Dec 2007, 8:38 pm
try connect different USB cable and USB port.
Old 21st Dec 2007, 12:22 pm
http://www.hacha.cn/ENG/support/index.asp
try this lol's
Review of Hacha PC90 louisnomad Reviews 0 11th Feb 2009 9:13 pm
Hacha PC20s David99 General Discussion 5 28th Jul 2008 8:41 pm
Hacha R280s Questions gelaskimgel Support and How To 0 15th Nov 2007 4:27 am
has anyone got the new HACHA PA20 player? liqourish General Discussion 2 21st Oct 2007 12:46 pm
Video review of the Hacha PA20 razzer001 Reviews 0 24th Sep 2007 10:37 am
