I need firmware mp4 with ak1025 like glacier
Old 20th Dec 2007, 8:08 am
Default I need firmware mp4 with ak1025 like glacier
I need firmware for mi mp4
CHips:
Samsung 737 K9G8G08VOM
AK1025
SP3767AHN
Board QY-066FVO
original firmware ACT_V9.1.52
Now is blank screen, and not firmware.
!Help pleaseˇ
Old 10th Jan 2008, 4:23 pm
Default Re: I need firmware mp4 with ak1025 like glacier
Hi.
Hope it helps.
I looked for my player on this site where all the images are posted, and found the same one (all be it a different colour). This led me to http://www.mympxplayer.org/glacier-r...evc-df621.html
This download includes loads of firmware (operating system software versions or .bin files) for glacier type mp4's and instructions on how to reboot the player if it is locked up.
Try them all with your upgrade utilities that came with the mp4, until you get ones that load ok then make sure you get the one out of these that starts the player into the correct start up screen!
PS Although the computer may not recognise it the upgrade tool probably will and say that the mp4 is in boot up state or something similar. (Prob no need to do the chip shorting bit unless you have no luck.) My player was a chinese 8gb (will prob only format to 2gb if it's the same Glacier type as mine).
Some flashes that seem to load ok allowed the player to play audios and not video. I tried a different one that also loaded and allowed me to boot to menus and this one played both, hurray. (This was the one that gave me the same welcome message on boot up as it originally had!)
I then set about using an amv converter recomended from this site and experimented with all sizes and frame rates and video settings. Mine would only play frame rates of 10 (12 and 15 would cause errors independent of resolution or picture dimensions!)
Good Luck
Tony
Old 15th Jan 2008, 11:27 pm
Dear Tony,
Can u please provide the firmware details of the firmware u referred in your post (a clown Juggling and "Welcome" in multicoloured letters). it had the exact same main menu as displayed on top page of dead player recovery tool kit. I have the same player (now dead) but no firmware available here or on s1mp3.org seem to be working....
pl respond..
HM
Old 19th Jan 2008, 6:46 am
hi~minglas
This is the firmware you need to download Address:
http://www.s1mp3.net/en/LG_LWL_QY-06...1_20070706.rar
Made in Shenzhen
Dead player
Old 22nd Jan 2008, 6:24 am
Originally Posted by s1fw";p=&quot View Post
hi~minglas
Link not found. other?
thanks
Old 22nd Jan 2008, 9:37 am
Hi,
Mine is the same player only in white. I had a little red clothed soldier and “Welcome” in multicoloured letters as the start up screen when it worked originally. The firmware that put it back and made the mp4 work again was 9.0.50_7.bin. Found in this download from this site.
you will need the 7-zip tool (free) to unzip the downloaded file…(just do a google for it).
If you need the firmware upgrade tool that I used (which came with the player) I have put it on my minimalist website
http://freespace.virgin.net/tony.saul
Luck
Tony
It worked for Mulka (see above).
Old 22nd Jan 2008, 10:39 am
Default Link
use this link
ftp://mympxplayer:mympxplayer@218.97...20070706%2Erar
Old 25th Jan 2008, 12:46 am
Thanks tony, but does not load that firmware.
adamquerido thanks, but this link not found.
already I have also that firmware, but no longer with himself to load none.
surrender, for my is damaged for always.
Old 26th Jan 2008, 8:10 pm
hi~minglas
http://en.s1mp3.net/LG_LZY_QY-066FV0_TFT70023_2091_V9.1.52_六键横向带外响(可修改)科为界面_2007 1028.rar
Made in Shenzhen
Dead player
Old 2nd Feb 2008, 2:36 pm
Hi! I am totally new to all of this. I don't think that this is the same problem, but I think I have the same player as all of you. I downloaded the repair kit thing from this site, but it seems to so extreme! In any case, my player turns on, but just stays on the hourglass indefinitely. Any ideas? Do I need to open it up and short out circuits and such? Thanks!
Looking for firmware Glacier 2.0" 8gb AK1025 7J041AB 03 mash033 Dead Players 3 28th Mar 2009 4:44 am
Glacier Repair Toolkit - How to fix glacier player alex2pb Support and How To 14 16th Dec 2008 1:51 am
Looking for Glacier like firmwares AK1025 QY-066FV0 amorfgr Dead Players 9 15th Apr 2008 3:46 am
glacier like mp4 ak1025 need 9.1.52 firmware UPDATE bladerunnerx_x Dead Players 6 2nd Apr 2008 5:36 am
Firmware required - Glacier MP4 9.1.52 AK1025 shah330 Dead Players 0 6th Dec 2007 4:58 am
