-   -   [solved] error message when trying to flash the firmware (http://mympx.org/forum/dead-players/40289-solved-error-message-when-trying-flash-firmware.html)
zrock 26th Jan 2008 3:11 am
hello there..just want to ask if what is the cause of error message when i try to flash the firmware (LG(xmc)_DX91008_CM60022_2091N_V9.1.51_070804.fw) and the error message is this "The firmware's protocol is not the same as the previous firmware's,please exit the tool and select the frimware"..i used Mp3 Utilities version 4.15..
hope you can help me with this.i been looking that firmware for almost a year everywhere but nowhere to found and when finally found it in (en.s1mp3.net) i was so happy knowing to relive my dead s1 mp4..
TNX A LOT..
s1fw 26th Jan 2008 8:04 am
Please use this tool upgrade:S1mp3.net Firmware Upgrade Tool
http://en.s1mp3.net/?action=browse&s...&path=%2FTools
zrock 26th Jan 2008 8:13 pm
hello there s1fw..still that s1mp3.net upgrade tool does not work..still the message "The firmware's protocol is not the same as the previous firmware's,please exit the tool and select the frimware"..appears and i try to select all the firmwares on the (en.s1mp3.net) and its all the same that error message appears all the time in all firmwares..
what do you think is the problem?hope you can help me with this.just to share my idea,i think all the firmwares there are encrypted,what i mean is that theres something a security in all the firmwares..
help me with this please..TNX A LOT!!!
admin 27th Jan 2008 12:05 am
Re: error message when trying to flash the firmware
Hi zrock,
Can the s1fwx tool (available for download from this site in the "Tools" section) detect your player? If so, what does it show?
Have you also tried the other firmware files from OUR site as well? I would be interested to see what happens there and whether you get the same error message.
The other option is have a look at this post here --> Recommendation: Try different MP3 Player Utilities.
Maybe you need to try a different version of the MP3 Player Utilities?
zrock 27th Jan 2008 2:01 am
hello admin..my player is in ADFU mode already for almost a year and all i need is to flash a compatible firmware and when i found it in (en.s1mp3.net) i expect that my player would be relive finally but that error message gets in the way..yes i tried all the firmwares on the download section here in mympxplayer.org and that error message does not appear unlike the firmwares on en.s1mp3.net but still none one of the firmwares here fits my player..i tried to download most of the firmware in en.s1mp3.net maybe 20+ randomly choose firmwares and still got the same error message all the time..but so far i havent used all versions of mp3 utilities..i'll try it..hope it will work..tnx for the advice..
zrock 27th Jan 2008 10:27 pm
tried all versions of mp3 utilities but none of those works
hello there s1fw and admin..i have tried already all the versions of mp3
utilities from version 1.28 to 4.15 but none of those works for the firmwares
on en.s1mp3.net..still i got those error messages when i select the
firmware..for the older versions the error message goes like this "Invalid
upgrade firmware file" & "Read or write device information failed! Please exit
the program and check if device is connecting" and for the new versions of
upgrade tool goes like this "The firmwares protocol is not the same as the
previous firmwares,please exit the tool and select the firmware"..NOTE
THAT ITS ONLY THE FIRMWARES ON en.s1mp3.net HAVE THIS ERROR
MESSAGES THING AND ALMOST ALL OF THE FIRMWARES THERE HAVE
THIS SAME PROBLEM..maybe you guys should try for yourselves to run a
upgrade tool and select one of the firmwares in en.s1mp3.net and for sure
you will got that same error messages im reffering to..
hope this problem will be fixed because en.s1mp3.net would be very very
useful for users with dead s1 players to relive their player..
TNX A LOT!!!
gogomanu 28th Jan 2008 1:32 am
Zrock, try to delete the unknown (chinese) characters in the name of the file s1fw sent you, not the "fw" extension :). Hope it works
zrock 28th Jan 2008 6:23 pm
okay tnx gogomanu i'll try it..
zrock 28th Jan 2008 6:48 pm
a big tnx to gogomanu
hey there..tnx a lot ur a genius..that rename thing do the job..i have relive my player finally since after more than a year..but i have a problem again..hehe..the firmware i have flashed to my player its not too compatible for my player..all buttons dont work..hahaha..the firmwares date is 2007.9.16 but in my players board is 2007.1.19..it has a big difference you know..hahaha..
so i need your help again..yeah i have read the post HOW TO FIX BUTTON CONFIGURATION but i think its very hard to learn and takes time..any advice for this?..TNX IN ADVANCE!!!!
gogomanu 28th Jan 2008 11:06 pm
Hi there, I'm very very glad to hear your mp4 is back to life. That thing (deleting the characters) I knew it from my own experience. Unfortunately I don't really know how to fix the button problem....I haven't run into that (yet) because my player is still dead :( . Try asking admin or tadad or people who really know what they're doing....I'm still a rookie in this business and all I know is from my own mistakes :D . Good luck
