HELP WITH ONLOOK A LIKE
Old 1st Feb 2008, 11:56 am
Default HELP WITH ONLOOK A LIKE
Hello I ma Having trouble with a type of Onda vx858 look al like i ahve looked into all the upgrade types for the player on both oem and the orginial firmware and they seem to work but when i start it up hit my touch screen where the main menu shows up the screen changes to hold with a phto of a folder and i already know how to get to mp4 upgrade mode form rock usb and i will give you the chipsets as followed. None of the chipsets match the other ones excvept for the rochk chip PLease your help would be really appreciated Please reply.
Rock Chipset
RK2608A-B
B79650 0749
Hynix Chipset
hynix 635A
HY57V161610CTC-7
36b63732p
Memmory Flash
Samsung 749
K9HBG08U1M
PCB0
CSKB40P4
Thank You Archen
Old 10th Feb 2008, 5:59 am
maybe you should try all the firmware here..
http://en.s1mp3.net/?action=browse&s...OCK2608%20Chip
good luck..
